I've actually owned a '98 Neon R/T before. I just bought this for 1500! It's intent is to relieve fuel cost from the Jeep on my 600 mile/week commute. And to be a track rat while the Honda is down. As many of you know my Honda has ran less miles in the last 3 years than I have and I'm 275lbs...
Here is the list from the for sale ad:
DOHC Engine
White with Blue Stripes
car was rebuilt about 5 years ago. It has a lot of upgrades on it that include:
Cold Air Intake,
Larger Throttle Body
Comp Cams #10 camshafts
New valve springs
Valve Job
Valve Seals
Adjustable Cam Gears
Water pump replaced
Starter replaced
alternator replaced
Under pulley
Head Gasket Replaced with MLS gasket
Timing belt has about 40,000 miles on it.
Replaced Engine ECU with Mopar performance ECU.
Mid length headers
Spark plug wires and MSD module
New Radiator
Oil Pressure Gage added.
Engine was rebuilt when all this was added.
Limited Slip Differential- trans was gone through at the same time.
Upgraded to 2001 Neon Front hubs, bearings and half shafts
New Tie Rods, ball Joints
Poly bushings in engine mounts and front suspension. I have the rears but those have not been replaced.
stock aluminum rims with new tires
Spare set of wider rims 15 inch.
BC Coilovers
Replaced rear wheel bearings
Calipers and Steel braided brake lines and rear steel brake lines replaced
Replaced master cylinder
SRT4 Front drivers seat
Power Windows and door locks
It's a bit rusty, but mechanically sound lol.
DOHC Engine
Cold Air Intake,
New valve springs
Valve Job
Valve Seals
Water pump replaced
Starter replaced
alternator replaced
Under pulley
Mid length headers
New Radiator
BC Coilovers
