Upper Control Arms hitting, cut a hole?
    When the camber is adjusted, I believe the arm is allowed to sit a bit lower, and it doesn't travel enough to hit.
    Accordtunerx, the founder of this site, discovered that running -1 degree of camber with Neuspeed Race springs (2.2" drop in the front) resulted in no contact.
    at 0 degrees pretty much only had contact on extreme dips at a slow speed, a solid wack. with regular ubj's i have -2.65 natural camber (~2.25" drop)..i had to switch back; the SPC's were feeling "floaty" at highway speeds.They had maybe 25k miles on them and about 50 hits
      you can try filling in the two pieces with gap filling foam and then all weather caulking to seal up the cracks.
      After my anchor type camber kits dug into where my control arm bolts to and tore the sheet metal away, i took it to a fab shop and he cut a custom piece to restore the fatigued and cracked metal. I painted it after that and it's been good since for about 7 years now.
      They're professionals for a reason and would know the best way to cover this up/make an access panel. The guy only charged me about an hour's worth of labor so roughly 60 bucks to cut, and weld that piece in the D/S front, rear control arm hole.
      member's ride thread
      91 Accord SE 176k
        also ditching a balljoint kit for an anchor bolt kit will give you back whatever you lost from the increased height of the balljoint. And when you're lowering a car a significant amount every little bit counts. I've never had any banging issues, and have been pretty dang low (tucking tire on 17s).
          Why are you in Canton, MI?
            Can't believe all the body filler suggestions here for the gap between layers, bleck.
            Heat up the bottom layer (doesn't take a lot) and body hammer it up against the top layer, and then weld the perimeter. Weld on a cap if wanted, then follow with proper prep/primer, etc.
              Good idea and the metal is soft but the pieces are the same length. He would have to cut the top by 1/4" and then bend the bottom up over it. Tricky but easy to do with a dremel and pliers. Heat if needed. Good idea. Not that this would make it water tight but still a good idea.
              Actually isn't there a tool to "crimp" metal together? Like a seal maker....
                My suggestion of piping in a sealant was made with the knowledge that I was making it to a 17 year old that has already opted to ignore advice on the right way to do things in favor of the cheaper, easier way. He can't weld, and the cost to weld up those holes would probably be prohibitive.
                I do agree that it's the best way to do it, though.
                  I moved to MI for a job
                  91 Accord SE 176k
                    I do see your point. Better to do something than nothing.
                      I'm faster then a prius
