Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 03-17-2019, 10:15 AM   #1
thepowderblue
CB7tuner Member
thepowderblue seems to have made some friends! thepowderblue seems to have made some friends!
Send a message via AIM to thepowderblue
Injector options for boost
I was wanting to make a thread with options for bigger injectors for boost that will fit in our cars with out modifying the fuel rail. Impedance does not matter or having to change orings does not matter.
Post up what you know works
We allways hear dsm injectors or RC injectors are good but what cars do we buy them for?
Like i know rdx 410cc injectors work but there only 410s.
What do dsm 550s come in and is there any cars I can look up to find a part number?
I am going to need at least a 550 but would like to use 750s
I am wanting to find Bosch or denso injectors for another car that will fit in ours for mybturbo setup. Rc's are expensive and I have had bad luck trying cheap no name ebay injectors
thepowderblue is offline   Reply With Quote
Old 03-17-2019, 01:37 PM   #2
Grumpys93
Contributing Member
I use to run DSM 2G Eclipse Blue tops 450cc when I first was boosted, only mod I had to do to make them fit was stretch out the rubber o ring that sits in intake manifold where the injectors rests up against.
I am about to run Injector Dynamics 1050x which require no modification other than creating a wire harness plug to convert our plugs to mate with the injectors, or for I think 20 bucks more you can buy their plug and play adapter which made it way easier.
Also Injector Dynamics can run E85 or pump gas.
But im not sure if you are looking for OEM injectors or just injectors in general.
__________________
~Nick~
Old 03-17-2019, 05:13 PM   #3
Jarrett
Contributing Member
The hands down best bang-for-your-buck injector is the OEM injector in the '13-'14 GT500. It's a 600cc injector that only costs about $31/each. It's the Bosch EV14 design so will run brilliantly and will allow for rock solid tunes.
__________________
Old 08-09-2020, 10:30 AM   #4
thepowderblue
CB7tuner Member
Quote:
Do you know if they will work in k series?
Old 08-11-2020, 10:35 AM   #5
PR CB7
CB7tuner Member
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
Quote:
They will, of course they will require a tune.
I agree with Garrett, usually if you want anything under 700cc, try to stick to OEM vehicle injectors like the GTR or GT500.
Dont put too much focus on not wanting to modify the height, injector price/size and fuel pattern matter more than a an additional or removal of a spacer.
__________________
Quote:
Originally Posted by deevergote View Post
Just do what PR CB7 said.
PR CB7 is offline   Reply With Quote
