Originally posted by Jarrett
View Post
JTC Customs Short Throw Shifter Review
Originally posted by johnl View PostWith a short shifter it may be advisable to slow your hand down a bit. When the shift timing is correct for what's happening inside the box then the gear will lightly slot in with a click, if wrong then you'll feel a resistance at the lever as the cones are working hard, more so the shorter the shift action is.
Originally posted by sonikaccord View PostSo that's why I'm faster when I shift in a smooth, fluid motion rather than a fast, jerking motion.
If the synchromesh isn't quite as strong as it should be, then adding more stress onto the cones (by shifting too quickly) could also cause them to not work as effectively as they otherwise might, which could cause crunchy gear changes and eventually wear the tips of the dog teeth as they clash together. I have a slight problem with third gear (since I bought the car), if I do rush the shift then I can easily cause the dog teeth to graunch. Get the timing right and it's no problem. This became less of an issue after I installed a lightweight flywheel.
Also, when shifting to a higher gear the engine rpm need enough time to lower enough before the clutch pedal is released, or else the shift won't be smooth. If the engine rpm are still significantly too high as the clutch re-engages in the next higher gear then the car will lurch forward as the rpm are forced down, which gives a tiny amount more acceleration, but is hard on the clutch. This is all too easy to do if the shift is performed very quickly, which a short shifter can make more easily possible. A lightweight flywheel helps engine rpm fall faster, as does disabling the damn IACV valve...
Something I've found with the light flywheel (and disabled IACV) is that if the AC is on it can add enough drag that the engine rpm can drop fast enough that I have to be very quick completing the gear change (to a higher gear), or else the rpm will have fallen too far by the time the clutch is re-engaged, causing the car to lurch as I let the clutch pedal back out.
Something else that might have a significant affect on the speed with which the internal rotating gearbox components synchronise their rotational speed is the rotational mass of the clutch driven plate. I've never driven with one, but I suspect this might be an advantage of 'puck' style driven plates, i.e. there is less mass in the plate than a more conventional 'full circle' driven plate, and so they may improve shift speed(?).
A short shifter is at it's best when mated to a close ratio gearbox and a lightweight flywheel. These three things working together will make faster and smooth gear changes much more possible (both up and down shifts) with less stress on the gearbox and clutch, but it's all in the drivers skill and timing to make the most of it.Last edited by johnl; 11-25-2014, 01:48 AM.Regards from Oz,
John.
Originally posted by Raf99 View PostI had two questions as I've tried other shifters and they all seem to have the common issues with our cars.
1. The rubbing on the center console, but this was already temporary answered.
2. The "notchy" gear selection that occurs with these.
The prelude shifters also don't really match up with the bolt holes where the rubber boots sit but they will all go in. But it was the notchy / "doesn't want to go in gear" feeling that I hated and how most would ruin their tranmissions. Do you have any such issue with this shifter?
Thanks for the write up too!
2) Yes i believe its a bit "notchy" however i also don't think its a terrible as some of my other cars I've had, with their short shifter applications. As someone mentioned i also have a ls1 Camaro, and the Hurst shifter i have in that car is much more abrupt/notchy. This one (for a lack of a better word) is more refined??? If you want a ball park idea of how this shifter feels grab your stock shifter below the knob a bit, and row through the gears, its pretty similar in my opinion. Also don't forget this shifter is adjustable so in different settings it will feel different. Hope this helped and let me know if you have other questions, btw love the setup h22 turbo.
Originally posted by Davids92Accord View PostThe shifter looks great but is the asking price $175?
Update: After a few months of driving (about 3000 miles) with this shifter i have to say i'm really satisfied with the purchase. The only issue if you want to call it that even, is the adjusting bolts back out a bit from time to time, and need to be tightened with the supplied tool. However loctite seems to have solved that for the most part, and my cable I'm pretty sure has worn a grove under the console so it has free'd up, and kinda fixed itself of the rubbing issue, but i did file it down a bit. Looking forward to getting more stuff for the CB, in the near future.
Originally posted by sepulveda87 View Postare they even in business anymore? no answer when called or email backs
He had some family issues, which held him back from some orders, but then he said he was going to come back strong with a new website and processing system.
He did the website, but all orders were not getting filled or responded too, and then he just sort of dropped off the face of the scene.Hafa Adai!!!(Hello and How are you)
Originally posted by rubycoupe View PostI ordered mine in october 2014, however i did send an email, and didn't receive a response back but got the shifter...
Which is very weird because once you have an issue who will be the one to talk too?Hafa Adai!!!(Hello and How are you)
Cheddas Auto is coming out with a adjustable Short Shifter for the CB and prelude chassis... they are taking pre-orders now... Ordering 2 tonight for myself and my boy.. check them on Facebook and there site http://cheddasauto.com/
