#21 |
It has began! Crack my hub nuts, and drained all fluids. Looks like I'm gonna have take the tranny to a carwash a degrease it, lot of crap on it. Keep you guys posted.
#22 |
Well some parts are not gonna make it back onto the car. The wire harness that hooks up all the sensors was covered in oil and extremely bridal, heading back to the back to the JK.
I got a lot degreasing to do from the entire engine, tranny is the worst. Keep you posted. |
#23 |
Don't everyone get back at me at once! Anyways that harness is got to be swap out, does it have to be the same year and engine?
Also, A/C tubing that goes towards the firewall, can I coated that with something to have my entire piping insulated. It appears it was coated with some black primer, but hardly none is visible. What options do I have to insulate the remainder A/C piping? Thanks |
#24 |
Depends on what side you're trying to insulate. If you're talking about the low pressure side then just use some radiant barrier from Home Depot. Don't insulate the high side as it will make it less efficient. The high side is supposed to dissipate heat, not hold it in.
Sorry I don't have a CB to go and look at the lines on so I don't know what side you're talking about. I would get the same year/engine harness to make it easier on yourself.
#25 |
I was talking about the A/C lines on the passenger side along with the heater core hoses. Gonna go check the product at Home Depo.
Got the harness yesterday from a 92 sedan lx, I have a coupe. Paid $30 bones out the da door. |
#26 |
Its out. I have my engine and tranny separated, replacement block sitting in my back patio. I'm gonna need all motor mounts, where can I get new cheap motor mounts, anyone?
Should I DYI polyurethane repair job on them? Last edited by laloquera; 08-15-2016 at 03:43 PM. |
#27 |
Rockauto is most likely your best bet.
#28 |
I will check it out. Anyone else?
#29 |
rockauto if you want new. otherwise, dealer or junkyard.
#30 |
just got them today trough rockauto. Any parts I should keep from my old short block before I two can it? Having extra parts would be good.
#31 |
Any parts worth keeping off my short block before I send to the recycler, Anyone?
#32 |
I'm dealing with seals. Got to go out and get rear main seal and that round seal in the tranny housing. Any other seals I need to replace, before I put this thing back together? Thanks!
#33 |
k, swap out cam, crank and balancer seals. Tomorrow I swap out rear main seal and rear/front balance , oil pump seal. Is it a gasket or a seal, or both? Not sure how to do it. Anyone?
#34 |
Im done. this project is done, drove the car home from the storage yard today. It took me almost a year to complete. Out of pocket expenses were $300 and lots back freaking pain.
I got a few issues but gonna post up in a separate thread. This was a personal accomplishment, I knew there would come a day I would do a an engine swap, I can know scratch it off my bucket list. Peace |
#35 | |
Luckily I found a F22 short block in great shape from a guy on Craigslist for 50 bucks so no JY tedious work to remove the engine was necessary. I also had AlmostJDM come and help me out during his holiday vacation otherwise it probably would've taken a year like yours did. Its amazing how motivated you get when you have someone working with you on the project.
![]() member's ride thread 93' EX Coupe H22A w/ P2T4 Sir 5spd 191whp 155 wtq 97' Lexus LS400 289k miles.....Luxury Cruiser DD 89' SEi Coupe 42k miles one owner museum find |
#36 |
ac blah blah blah
I seen they thought that guy well in school and he is right but u can don bolt the a/c compressor from the motor without discharing the system just cut the belt or relase the tension. Un screw 4 12mm bolts at the compreesor just move fan for clearence
a person who looks at somthing and see it as waste is no person at all but he who see what it could be will suceed ![]() ![]() |
#37 |
$50 bones for a short block, that's a sweet deal.
I was able to just slide my a/c pipes very carefully and unbolt the 4 bolts. I recharged my a/c system just in time. Temp is here in NorCal is getting hot. |
Thread Tools | |
