Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 03-19-2017, 08:10 PM   #1
JTL_91CB7
JTL_91CB7 is cool... so far.
Highest offset for a stock cb7??
I'm still trying to get familiar with offeet measurements. I want to have a positive offset on my stock ride but I don't know what can fit. I love the wide track width look but I can really only afford some wheel right now. What would be the highest offset wheel I can put on my car, without camber, rolled fenders or anything, without my fenders ripping my tires to shreds?!
JTL_91CB7 is offline   Reply With Quote
Old 03-20-2017, 09:00 AM   #2
Raf99
+38 offset I would say. Assuming you may have 4 people in the car, hitting dips, etc.
Old 03-20-2017, 09:56 PM   #3
CyborgGT
CyborgGT is cool... so far.
It depends on wheel width. I'm not sure on if/how these cars were modified to make them fit, but here are some examples:
17x7 +35:
17x7.5 +40:
17x8 +35 front, 17x9 +35 rear... no idea why this guy put the wider wheels in the back on a FWD, but here you go. Front camber looks like it might actually be stock, where rear was definitely tilted in a little bit with fender roll.
Old 03-21-2017, 04:19 PM   #4
Raf99
You should post those in the signature link I have for wheel offset
Old 03-23-2017, 08:19 PM   #5
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
Highest? Or lowest?
If you go too high, you end up needing spacers. I believe the 96 spec ITR wheels were something like +50.
I think you mean lowest offset.
Also, tire size plays a huge role into how everything fits. Personally, I had a 215/45 on a 17 x 7, +40mm and could rub with people in the car on a mild drop.
Suspension settings, tire choice both in size and brand, wheel width, and wheel offset all play a factor in what will fit or what won't.
Unfortunately, there is no blanket statement answer in this question.
AccordWarrior is offline   Reply With Quote
Old 03-25-2017, 10:19 AM   #6
CyborgGT
Sure there is. Blanket answer: "ALL THE OFFSETS!!1!"
