INT: honda Prelude steering wheel conversion on 90-91 cb
    I've already trimmed it down considerably with an angle grinder. Maybe keep going?
      you should only sand down till the back stops rubbing when you turn the wheel, also did you swap the accord clock-spring with the prelude one?
        It sounds like it still rubs a little, and it feels really tight when I turn. The steering doesnt kick back easily like it used to. I have to help the wheel back after a turn.
        I installed the Prelude adapter, but I didnt replace any spring. So that must be my problem right there. I'll look into that tomorrow and report back.
          I trimmed down the wheel some more. Doesn't rub anymore so it's all good.
              i did this a while back and loved it and yes if you use washers it will stop rubbing. mine also had 4 wires the purple ones are the horn and the others are to the cc
              i used all the original parts on the colum just took the plug and connected it to the wires on the wheel
              my wheel is a jdm series i love the orange japan letters on the cc and it says japan on the back of the cc box,,
              excellent write up mad props... i used the older model on mine...
              from this
                ive always wanted to do this but i never did i love these steering wheels
                Nerotenzo@aol.com
                Facebook me
                http://www.facebook.com/home.php#!/Nerotenzo
                  Love that JDM wheel!
                    awesome write up but just to let you know you dont have to cut the wires... what i did was de-pin them one by one and just plugged it back up so it looks stock.... heres a pic of it installed... ill take it apart tomorrow so you can see what i did....
                    DELTA CAM GROUP BUY
                    http://www.youtube.com/watch?v=PSbCQuhAnNcla gringa pt.1
                    http://www.youtube.com/watch?v=hMz-F2saG_ola gringa pt.2
                      i <3 that wheel
                        been on the hunt for one of these wheels, going to 2 junkyards this weekend!! Cant stand my ugly looking one!
                        -LoS
                        " The value of life can be measured by how many times your soul has been deeply stirred " - Soichiro Honda
                          So how about making the cruise control work?
                            it does work if you wire the plug correctly... oh and if your cruise control works...lol
                            DELTA CAM GROUP BUY
                              -LoS
                              there are like 5 of these in the junkyard where i got mine bro... let me know if you want one
                              DELTA CAM GROUP BUY
                                Originally posted by darkfusion42 View Post
                                When I did mine recently I just test fit it in an abandoned parking lot, then got my car driving straight, then took the wheel off and adjusted to make the wheel sit straight.
                                There is also an arrow that points up on the hub adapter...the two "nubs" should be on each side.
                                The only issue I've had is I cant get it EXACTLY centered...always a tick to the left or the right...not too bad.
                                pic:
                                your truly came out clean with the h badge
                                Nerotenzo@aol.com
                                Facebook me
