Originally posted by Rilas
View Post
What other things to get when replacing tranny and clutch?
Originally posted by fleetw00d View PostPlate at the bottom of housing is #1 in the diagram; it is right next to the end of the oil pan.
The rear main seal does seal engine oil. If it is leaking and getting on the clutch plates and/or flywheel, it could cause issues.
A leaking clutch master cylinder (separate issue from rear main seal, both may come with age) may result in the fluid being too low to properly operate the clutch, causing issues when trying to disengage/engage it.
Originally posted by Rilas View PostRaf the inspection covers don't add any structural rigidity. They are just a stamped steel plate.
The only way to reinforce the bottom half of the connection is to get the H22A4 aluminum oil pan and the transmission stiffener plate and bolt them together.
https://www.ebay.com/itm/97-01-HONDA...UAAOSwYxBaHyQl
Originally posted by Rilas View PostThat is the actual stiffener plate that you linked. You just have to have the oil pan to go with it.
