So I was getting my car ready for its maiden voyage (excluding two trips around the block and a drive to the inspection station a mile away) yesterday and I was reinstalling my alternator and power steering pump in the rain. It was extremely dumb of me to be doing electrical work in the rain and on top of that my battery was reconnected. I never do this but I was in an extreme hurry and forgot. I get everything installed and get in the car to drive off. Many things are haywire and I'll list the electrical problems.
The left indicator switch doesn't turn on any of the front signals, only the back at a rapid pace. It also causes my speedometer to bounce and the cruise light to flicker if I do it while driving.
My cruise control does not work and it also causes the speedometer to bounce when the button is pressed.
My wipers have a mind of their own when the switch is turned. When they're on the intermittent setting their movement is not fluid and is very notchy and irregular. When I turn the switch off it takes them a while to actually turn off. It may be three more passes or ten.
My hazard button works all of the lights except the front left but it also triggers the wipers and their slough of issues.
The car worked amazingly before this. I bought it non-running but was still able to test all of these features before and after I replaced the engine. Whatever I did yesterday in the rain has caused the issues. My only course of action so far has been to replace the A02 module with an A11 module I had lying around. This did nothing. I've checked the connectors in that front left vicinity and everything seems to be fine. All grounds are intact as well. If anyone has any suggestions that would be fantastic. The car drives okay but these issues should be fixed sooner rather than later. Thanks a lot.
