So I got a set of foglights off a '90 Accord from an all-Honda junkyard, the guy must not have known what they were worth cause he only charged me $40CA for the lights, brackets, swicth and full harness. I brought them home and cleaned them up a lil, one was broken in the back, but only the plastic, not all the way through to the inside of the light.
Driver's side:
Passenger's side:
Harness and switch:
Removing the bumper was a pain because the nuts for the bumper support are stripped, so I decided to just remove the cover.
The plastic expansion clips were hateful because they wouldn't come back out with a screwdriver, so I tried something different:
I screwed in a small screw, only a lil bit:
Grab the screw with a set of pliers and pull the plastic center out:
I used a flat screwdriver and hammer and broke out the ones under the headlights. Piece of cake, the cover came off easily:
Then I used a utility knife to cut out the covers:
Keep reading below
Driver's side:
Passenger's side:
Harness and switch:
Keep reading below
