Our race 93 lx with a prelude transaxel is giving us trouble. Fully depressing the clutch pedal dose not fully disengage the clutch. We've bled it.
Clutch won't fully disengage
1993 Accord Lemons Race Car, "SpaceEx Starship"
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake FluidTags: None
Originally posted by ukemike View PostOur race 93 lx with a prelude transaxel is giving us trouble. Fully depressing the clutch pedal dose not fully disengage the clutch. We've bled it.
Or the pressure plate fingers have broke/cracked.
Originally posted by sonikaccord View PostIs your shift fork fully extending?
Is your clutch disc installed in the correct orientation?
Is your clutch engagement height set properly?
How do you set the clutch engagement height?==========================
Originally posted by sonikaccord View PostBy adjusting the clutch master cylinder pushrod under the dash. Break the locknut loose and you can adjust the height by turning the pushrod.
Thanx all!==========================
