my k24 swap...
    yea. side note// its pretty crazy feeling it boil the tires off in 1-2 gears. feels faster than my rs at times too. damn it lol
    COUPE K24
      couldnt let it go... running better than ever.
      COUPE K24
        This is what I like to see
        ~Nick~
          You did a manifold swap, nice!
            That’s so nice. I want this swap. I might have to pm you for some specifics.
            ~Mark~
              Considering a base-level K24A engine and transmission can be had for around $500, there are mounts readily available, there are OEM axle options and a tuning solution that doesn't require standalone, it's crazy that it's not done more often.
                thanks.
                yea rbc made a huuuuuuge difference. also have a 74mm tb.
                its pretty straight forward.
                this. most everything is available now. everybody should a k series.
                COUPE K24
                  Ok so the ecu is a Honda k series ecu? The swapped intake manifold is the RSX-s one right?
                  Man I gotta do this. It’s perfect for the direction I’m taking my car.
                  ~Mark~
                    i have a pnd base ecu with kpro v4. the intake manifold is from a 06-11 civic si.
                    COUPE K24
                      So did you buy a separate harness that goes to the ecu? Or build one that mates with the CB harness or something?
                      ~Mark~
                        bought one used. many people make them now. the only thing about the harnesses is they are all different and wired different. mine has intergrated fan control so it works like factory using the oem plug but ive seen some that dont which you have to wire the kpro to your fan relay. the rest is pretty similar.
                        COUPE K24
                          You mean I have to custom build it to my liking? Hmmm...I think I can handle that. I better study up though. I think you have to have the diagnostic plug added also for getting bared in California.
                          ~Mark~
                            yea it really wouldnt be hard to make your own. most people wont do wiring though. mine has a dlc but it doesnt work. i just use the cable from the ecu.
                            COUPE K24
