Idle Adjustment Screw Replacement
    Searched PP and cb7tuner and could not find a definitive answer on how to replace the Idle Adjustment Screw (H23a1 should be exactly the same for F22 and H22's)
    Is is just as simple as turn counter clockwise until ejected or is where more to it than that? Mine was so freaking tight on there it was ridiculous.
    IACV and FITV blocked off and the idle isnt that bad ( steady at 1.2k RPM with a/c on ), but typically like it to pur at 800
    Thank you very much in advance
    [COLOR="Magenta"]
    just keep on turning!
      easier said than done, but thanks for the confirmation
      . i think im going to end up having to drill it out at this rate because its IN THERE!
      [COLOR="Magenta"]
