Old 05-10-2009, 05:43 AM   #1
low-keyseg92
CB7tuner Member
low-keyseg92 is cool... so far.
burning oil and auto tranny????
My first problem is the burning oil. The car does not appear to burn oil under normal driving but if I floor it it lets out a small cloud. My first thought was rings, but it lets out a large cloud of smoke after sitting a day or so when I first start it. That tells me valve guides. I had the head completely (oem) rebuilt. Is there something im missing? Any suggestions?
Second its an auto tranny and when I start it the RPMs jump to about 2500 then come down. Then when going from D to N to R and back to park the RPMs jump up betwen gears. Any ideas?
The car seems to run and idle nicely.
Its a 93 door with an F22a6 with DC sports exhaust and aem intake. New HG,timing belt,gaskets,etc. Any suggestions would be appreciated.
After doing some research I guess the rings could be causing it also. (oil burning that is). I had always thought the rings just caused smoke while driving. Either way, I guess ill do a compression test and see where I stand. Still need help with the auto tranny parts. Thanks
low-keyseg92 is offline   Reply With Quote
Old 05-10-2009, 07:26 AM   #2
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
The revving between gears may be the IACV. Surging idle seems to be a common issue with our cars. This is the first I've heard it described that way, but it's usually a problem reported by those with manual transmissions.
Have you checked your spark plugs? I'm sure that if the head was rebuilt, new sparkplug seals were used... but that is one way oil could get into the combustion chambers. Check to see if they're wet.
It definitely sounds like an oil leak in the head. Rebuilt or not, something may have failed, or something wasn't installed properly.
__________________
deevergote is offline   Reply With Quote
Old 05-10-2009, 11:48 AM   #3
low-keyseg92
CB7tuner Member
I have changed many and IACV...on B and D series motors. It does not continue to ramp up and down. It goes up to 2500 then drops to normal idle. I had the head rebuilt at redline and tey have done several other heads for my civic. Im sure I am going to have to do the rings. I did it on my B so im sure I can do the F. Either way my main concern is the tranny problem. The fluid looks good and it shifts nicely while driving. I need to check the shifter cable. Thanks for the input tho.
Old 05-10-2009, 11:55 AM   #4
tn_accords
Contributing Member
tn_accords is cool... so far.
sounds like an issue with vacuum and the transmission air control valve. do a intake cleaning.
__________________
Quote:
Originally Posted by Devergote
A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
tn_accords is offline   Reply With Quote
Old 05-10-2009, 04:55 PM   #5
low-keyseg92
CB7tuner Member
Ill check that out. ty. I did clean the intake runners but I have yet to open the manifold and change the gasket. I will pull the egr and clean it also while im at it.
Old 05-11-2009, 01:47 AM   #6
wed3k
Contributing Member
wed3k seems to have made some friends! wed3k seems to have made some friends!
Send a message via AIM to wed3k
do a leak down...
the valve guides were probably not checked when the head was rebuilt.
__________________
I <3 G60.
wed3k is offline   Reply With Quote
Old 05-11-2009, 06:51 AM   #7
low-keyseg92
CB7tuner Member
Thats what I am thinking. It will be next weekend before I get back to working on the car but ill post what I find. ty for the info.
Old 05-11-2009, 08:55 PM   #8
low-keyseg92
CB7tuner Member
It was a vacuum issue. Number 8 line was reversed with the line from the charcoal canister. The tranny shifts good and the car is running good....except for the oil burning that is. Looks like im pulling the head again.
Old 05-15-2009, 09:29 AM   #9
low-keyseg92
CB7tuner Member
Update....I put new plugs in the car and ran it for about 5 min. and shut it off. I checked it the next day and there was no oil on the plug but a little in the cyl. I checke dit today ( 2 days later0 and the plug now has oil on the end of it. I would say the valve guides were not changed. It just happens to be the same cyl that had the burnt valve. I will now pull the head and have them fix it. Everything else on the car is good. Now if I could just sell the hatch to pay for wheels and coilovers....lol.
Tags
auto tranny , f22a6 , oil
