Old 09-29-2011, 05:24 PM   #1
jaemil369
jaemil369 is cool... so far.
oil leak somewhere
Just did upper and lower tube seals and valve cover gasket. I notice a oil spot under my car when I leave it parked for a couple days, any ideas???
jaemil369 is offline   Reply With Quote
Old 09-29-2011, 05:29 PM   #2
HondaCB7sb
HondaCB7sb is cool... so far.
oil pressure sensor, or maybe your oil filter is not on tight enough. either way they both leak from the same area (pressure sensor is right above filter and is common to go)
HondaCB7sb is offline   Reply With Quote
Old 09-29-2011, 05:38 PM   #3
cloudasc
cloudasc is someone to admire cloudasc is someone to admire cloudasc is someone to admire
99% sure its the oil pan gasket.
cloudasc is offline   Reply With Quote
Old 09-29-2011, 05:41 PM   #4
eightyfour84
eightyfour84 is cool... so far.
I got a leak too... Doesn't appear serious. Only happens when oil is hot and viscous. I'm 80% sure it's the oil pan gasket and also the oil apparatus above the filter, hopefully nothing major.
eightyfour84 is offline   Reply With Quote
Old 09-29-2011, 06:13 PM   #5
Leung
Leung is someone to admire Leung is someone to admire Leung is someone to admire
check by the distributor, i hear the o-ring there likes to leak down onto the tranny.
I'd also suggest checking the oil pressure switch above the oil filter.
Leung is offline   Reply With Quote
Old 09-29-2011, 07:03 PM   #6
fleetw00d
Where specifically under the car? Best thing to do is to clean the engine, then you'll be able to trace it better. Follow the oil up and forward. Under the left end could be crank, cam, or balance shaft seals, under the joint between the engine and tranny could be distributor or rear main seal. Head gasket and oil pan gasket could leak almost anywhere around. As mentioned above, if under the center back of the engine, could be oil pressure switch, oil cooler (if EX) seal.
90 LX 4dr 5 spd 384,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 191,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 09-29-2011, 07:50 PM   #7
jaemil369
Thanks for all the replays, ill check other seals tomorrow. I just went and got a o-ring which I know is leaking which ill be replacing tomorrow.
accord , fix , honda , leak , oil
