Old 03-15-2013, 04:27 PM   #1
iamninja28
iamninja28 is cool... so far.
Oil Leaking from Motor Cover
Im sure its just a gasket or something, but im making sure, heres the oil:
And here's the comparison to show its a legit leak:
(sorry if the pictures are big, my iPhone is stupid.)
Thanks for the help!
iamninja28 is offline   Reply With Quote
Old 03-15-2013, 04:39 PM   #2
deevergote
Don't call me dude.
Replace the gaskets
The entire valve cover gasket kit is something like $35 at most parts stores, I believe. Be sure to use Hondabond (or similar sealant) over the cam humps.
Old 03-15-2013, 05:29 PM   #3
iamninja28
just ran up to Advance Auto and got gaskets, used some silicone as sealant for the corners. Oil leak seems to have stopped. Thanks!
(now i just need to clean the bay itself :P)
Old 03-15-2013, 06:48 PM   #4
Revious
Revious is cool... so far.
I just replaced the same thing yesterday. Except I didn't use sillicone and it's leaking out a little, heh.
My leak wasn't due to a faulty gasket, though. It was because I could take the valve cover bolts off by twisting them off with my hand. Woops.
Revious is offline   Reply With Quote
Old 03-21-2013, 06:59 PM   #5
n8r4d3
n8r4d3 is cool... so far.
Replace the gaskets
+1
Next time try to use HondaBond as its made for stuff like this whereas silicone sealant might not work as well over time.
Case and point. oops!
n8r4d3 is offline   Reply With Quote
Old 03-21-2013, 07:31 PM   #6
reklipz
reklipz seems to have made some friends! reklipz seems to have made some friends!
I have the same leak around that acorn nut on the front of the engine. I replaced all of those gaskets and seals about half a year ago, and it's been leaking around that nut the whole time. I torqued down the nuts to spec with a torque wrench, and the o-ring/seal on the bottom of the oil cap is still in place.
I've swapped that particular gasket for another one at one point, but it didn't solve the problem. Is it possible that the o-ring on the oil cap is the issue here?
reklipz is offline   Reply With Quote
Old 03-21-2013, 10:24 PM   #7
STOCKa6
STOCKa6 is cool... so far.
I've swapped that particular gasket for another one at one point, but it didn't solve the problem. Is it possible that the o-ring on the oil cap is the issue here?[/quote]
Have any of your gasket sets come with the grommet that goes under the valve cover nut. I know some don't and that may well be the source. I have never heard of the oil cap leaking, but who knows with twenty year old plastic it could be leaking.
STOCKa6 is offline   Reply With Quote
gasket , leak , motor , oil , problem
