Old 05-16-2014, 11:08 AM   #1
Duhvidd
Duhvidd is cool... so far.
Exclamation Need help, bottomed out one too many times transmission bolt.
My car scraped a lot when it was running, so I am pulling my motor that has a rod knocking, and putting a new one in, and ive encountered an issue, my first tranny bolt is scraped flat, and it wont thread out, it keeps loosing grip with the socket.
Duhvidd is offline   Reply With Quote
Old 05-16-2014, 12:06 PM   #2
sonikaccord
A bolt extractor helps:
http://www.irwin.com/tools/screw-bol...olt-extractors
If that fails, you can drill it out and re thread it.
Old 05-16-2014, 12:10 PM   #3
XCRN
XCRN is cool... so far.
I was about to post those. They will not fail I used them on my transmission mounting bolts with great success. I think I needed to use it for 4 of the bolts.
Be unique, like every other person.
XCRN is offline   Reply With Quote
Old 05-18-2014, 05:36 PM   #4
LoganDavenport
LoganDavenport is cool... so far.
+1 for the bolt extractor, Mine has saved me multiple times. Its a good investment, and a good tool to have around because this wont be the last time you'll use it. If you're in to the whole slammed herra frush stuff.
LoganDavenport is offline   Reply With Quote
Old 05-20-2014, 03:21 PM   #5
Flip-Eye
Flip-Eye is cool... so far.
Ya save the ground scraping/sparks flying crap to the Volkswagon/Euro guys.
If you want to be lowered, do it right.
Flip-Eye is offline   Reply With Quote
Old 05-22-2014, 09:14 PM   #6
marvin75
marvin75 is cool... so far.
you can also weld a nut onto it if you have a welder if the easy outs let you down
marvin75 is offline   Reply With Quote
stripped bolt. , transbolt , transmission , transmission bolts
