Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 05-13-2017, 02:15 AM   #1
Jarrett
Contributing Member
Fuel injector suggestion for small turbo
I've seen a couple of fuel injector-related threads on here in the past few weeks so I thought I'd share something I've found while researching. The RDX injectors are commonly suggested as a decent injector for Honda applications because of their slightly increased fuel flow capabilities, as well as their relatively inexpensive price. What's also touted fairly often is their vastly improved spray pattern. I've even claimed as much myself. All of this is true. It does do all of these things well.
However, I believe there is a better injector available now that edges out the RDX injectors in terms of its benefits. The '13-'14 Ford GT500 injectors are even higher capacity AND are Bosch EV14-based. EV14 is the platform that all of the Injector Dynamics, FIC, Deatschwerks, etc. injectors are based on which is a proven design for high HP applications. They are also very capable when operating in the lower range of their duty cycle, allowing them to idle better than many older injectors. Especially the Keihin injectors these cars came with.
Here they are
RockAuto seems to be the best place to find them as they have them for $31.79/each.
They will still require hats to fit them into the OEM rail, as well as adapter harnesses or for you to modify your factory wiring harness to change to an USCAR-style clip. They are 57 LB/HR injectors which translates to 600cc/min.
__________________
If you see any threads or posts of mine whose picture links are broken (there are a lot), please send me a link to the thread. I will gladly fix them. I don't see it as a fruitless burden. This site has helped give me quite a bit of my drive and passion for cars, and fixing my picture links is the least I can do to give back.
Old 05-17-2017, 05:59 PM   #2
dbsharp
CB7tuner Member
dbsharp is cool... so far.
you can also get the light blue older wrx injectors and decap them. this will yield a 815cc injector that works great with our stock rail and intake ports
__________________
100,000+ miles of boost and abuse, and the engine finally let go. Time for a rebuild
dbsharp is offline   Reply With Quote
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
