f22 to an h23a?
    f22 to an h23a?
    I've been working on an h23a, non-vtec, complete rebuild. a friend of mine said that it would fit in my car. the motor is almost finished and know i need to know if the stock manual tranny will work on the new motor. and if so what kind of clutch and flywheel should i put on it?
    also what would be the best computer to put on the car? i would like to be able to program it.
    If at first you don't suceed, then skydiving is not for you.
    I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
    http://www.cb7tuner.com/vbb/showthread.php?t=159041
    The stock tranny will work fine and no need to mess with the clutch or flywheel other then having them cleaned and maybe throwing in a new clutch. A p14 is the computer your looking for. You will need to add a wire for the knock sensor. I think thats all you need. When you get a moment take a look into the swap section it will cover the process and tell you all you need to know.
    "Real intelligence is like a river; the deeper it is, the less noise it makes.”
    Click Me
      Chipped P06 ecu would be the ticket if you want to tune it.
      90-02 Accord or 92-01 Prelude clutch will fit, they are the same fitment, same goes for flywheel
      1992 Accord Wagon (RETIRED)
        i will go with the stock oem clutch it works just fine
          will i have to get another wire harness or will the stock one off my f22 work?
            The stock wiring harness, mounts, transmission, clutch, n flywheel will be just fine, only thing you'll need to do for the harness is add a knock sensor wire and Iab wire from the Ecu, and if you have a 90-91 get a distributor that is internal coil or if 92-93 get a distributor with external coil so it will match up with your harness
            Random Customs
            Praise the lowered
