Hey everyone this is my first post so hope it's a good one. So I got a H22 swap in my 92 accord and just got a oil pressure gauge with a sandwich for the sender. When trying to install the sandwich I noticed that I have an Oil Cooler attached so now I can't add the sandwich , plus it's dam hard to get an oil filter on because of clearance! So looks like I'm gonna have to remove the oil cooler to get the gauge on. Has anyone else had this problem and is there a way around this so that I can have both because cooler oil is better and I need the gauge too! Thanx in advance!
H22 Accord Oil Pressure Gauge/Oil Cooler Issues
you dont have to have the oil cooler on there. If you are going to remove it i would suggest doing it the right way and having the coolant nipples on the rear coolant pipe welded rather than plugging them.
member ride thread
DIVULGE MOTORSPORTS
John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "
EJX: I can't add the adapter on top of the cooler there's no clearence it's just not gonna happen, maybe if they made a REALLY small filter somewhere i could do it but it'd have to be really small.
Turbo: I think that sounds like the best idea so far, I know I don't need the oil cooler but nice to have.
"Live While You Live & Just Be Happy"
Originally posted by jazzmasterx View PostDoes anyone else have any other suggestions?
1. Have a 2ft hydrolic hose made with 1/8" NPT connectors on the end.
2. Goto home depot & purchase a brass T-connector
3. Remove the oem oil pressure sender under the intake manifold
4. Thread the OEM sender, the aftermarket sender, and the hydrolic hose to the t-connector
5. Thread the other end of the Hydrolic Hose into the factory sender location
6. Mount the T-Connector preferably somewhere on the block.
7. Connect the sender wires for the OEM & Aftermarket gauges
Holey crap Cloudasc this is amazing I assume you've done this before from the pics and the description? I think this might totally work but I've decided to just take the Oil cooler off all together because for what ever reason it's still a pain in the azz to get an oil filter on and I'd rather not deal with that. Thanks guys.
jmolina: How come yours just fits on? Cuz from the instructions clousdasc gave, I might not be the only one with this prob.
just go to glowshift and get the cooler instead of the adapter.
I did remove mine and just got the oil bolt off a F22.
It is smaller and not spaced out for the cooler, then I added my sandwich adapter.
good luck. is your oil press mechanical or electronic?
I am going with electronic since you said "sender"!
Originally posted by jazzmasterx View PostHoley crap Cloudasc this is amazing I assume you've done this before from the pics and the description? I think this might totally work but I've decided to just take the Oil cooler off all together because for what ever reason it's still a pain in the azz to get an oil filter on and I'd rather not deal with that. Thanks guys.
For the coolant and oil temperature senders, I had the block drain plugs tapped for 1/8" npt senders... that look like this:
Oil drain plug is located below the filter. Coolant drain plug is located to the right of the oil filter.
Cloudasc I'm so tempted to try your method. I'll look at my options today and see what I can do Thanks! Oh btw how long have you had this setup for?Last edited by jazzmasterx; 03-22-2010, 03:36 PM.
Originally posted by jazzmasterx View PostCloudasc I'm so tempted to try your method. I'll look at my options today and see what I can do Thanks! Oh btw how long have you had this setup for?Last edited by cloudasc; 03-22-2010, 04:34 PM.
Update: So I ended up having to take the cooler off and put a new fitting on like drummersteve7 sandwich fits now and I can put an oil filter on w/o having to try to find someway to make it fit! Still haven't hooked up the gauge yet I might do that tomorrow.
