OEM heated mirrors?
    OEM heated mirrors?
    did our cb's come with the option of heated mirrors.I was looking on ebay and found these-
    http://www.ebay.com/itm/320893107586...ht_2218wt_1168
    he says these mirrors are HEATED, they have 5 pin instead of four like usual. he has a couple he says are heated, the other ones just say powered.
    I believe it was an option (or a standard feature on better models) in Canada. I don't believe any US models had the option.
      yea everything he's selling is from other countries, so i'll go ahead and pick up a pair!
      i thought it was from canada because i know they have heated seats, but couldn't find anything but the acura cl heated mirror swap on here.
        Yeah, I had to look up "canadian cb7 heated mirrors" on Google, and it still didn't really give any concrete evidence. The Canadian members can probably clear it up pretty quick! OR tippey... because he seems to know every little rare detail about every foreign CB there is!
        You're going to have to figure out how to wire em up... we're certainly not going to be equipped with that wiring in the US!
          i want to hook them up to the defrost switch, i dont think it'll be too difficult, and ill document the process on here.
            They were on Canadian SE models and will physically bolt right in assuming they are sedan mirrors for your sedan or coupe mirrors for your coupe. The wiring can be done sort of like you are saying but lucifer1 recommends tying it in to the back of the fuse box under the dash. You want to tie into connector 503, I believe. It's a 2-pin connector that is right after the rear defroster relay so that the mirrors are on a relay as well.
              Heated mirrors came standard on '93 Canadian SE's only... Not sure if it was optional on other trims. That and the heated seats.
              It's because it snows year round up here bbbrrrr
                Standard stuff here in Finland too, nice during the winter with the polar bears. (Disclaimer: There are no actual polar bears in Finland)
                MRT: http://www.cb7tuner.com/vbb/showthread.php?t=197342
                  So its true that the heated mirrors and seats that my buddy and I would discuss do exist just were not produced here in the states?
                  http://www.cb7tuner.com/vbb/showthread.php?t=189897 MRT
                  http://www.cb7tuner.com/vbb/showthre...09#post3003309 EF hatch build
                    All the CB's I've seen here in Finland come with both equipped. So yes, definitely.
                      Yes, they came with the same switches that the '98-'99 3.0CL had. It's just a single switch for each seat that goes in the console.
                        if my research is right the heated element in the CL are the same as the CB. same pn and everything on the backside.
