Running Hot
    Originally posted by LinX
    You might have coolant system leak.
    a guy at auto zone said my head gasket was blown. if it was blown then i it would be overheating after like 1min of the car being on if not sooner right?
      If your head gasket was blown then you would definately know. There'd be smoke everywhere and the car would definately overheat in no time. You'd see coolant mixed with oil.
      ...adjust accordingly
        it could be a bad hose check all your hoses just incase i just replaced the thermo fan switch i suggest you check your fans and see if they work
        CLICK ON SIG FOR MEMBERS RIDE
        "2SIIC"
        Authentic Jerseys for sale
        http://www.cb7tuner.com/vbb/showthread.php?t=188314
          yeah, i checked them today and they arent running, and i got a thermo switch, so im going to install and see if it helps.
            lol....a blown headgasket doesn't have to be so disastrous. Or maybe the head is warped now. Aren't they aluminum heads? I forgot.
            Helped diagnose a car recently that has a slight headgasket leak, and all it did was put some compression into the cooling system. Not even enough to push past the rad cap. Car still ran good and at normal temp, but was slowly getting worse, then it finally started leaking into the clyinders and oil just as it got into the shop./
            Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
              well i just installed the thermo fan switch and now my car isnt over heating the fans turn on now so that has to be the problem dude cause it fixed mines
              "2SIIC"
                I had to flush more than once..
