Old 09-24-2019, 05:19 PM   #1
zedjr10
zedjr10 may have said something they shouldn't have...
Does crankshaft pulley reduce vibrations much? Are aftermarket ones better?
I have been reading about different pulley systems and wondering how much ours limits crankshaft vibrations. Some have balancers in them and thick rubber. I am assuming ours have thick rubber but nothing else. Why do they call it harmonic balancer when it is really a crank pulley it seems?
Is the newer aftermarket pulleys better than the oem one? I know rare case right but have read that the materials in these things have gotten much better.
Old 09-24-2019, 06:00 PM   #2
sonikaccord
The OEM limits it within the original design parameters of the engine which is data only the Honda engineers and third-party testers have.
It's a harmonic damper because it cancels out crank harmonics. Harmonics are very small twisting forces applied across the crankshaft. Excess harmonics cause all sorts of issues with the most severe being a broken crank or block.
I'm pretty sure a modern pulley is the same or slightly better than the OEM. It won't matter much on a street driven engine anyway.
YouTube Clicky!!
Old 09-25-2019, 05:51 AM   #3
CyborgGT
http://www.laskeyracing.com/shop/harmonics.htm
https://www.enginelabs.com/engine-te...damper-advice/
Old 09-25-2019, 11:23 AM   #4
zedjr10
good info man. Thanks.
