h22 accessory 93 accord/F22 Pulley what belts to i use / buy? accords?
93 Accord Pulley On a H22
How ever many ribs your crank pulley has (4) then that is the belt length you buy.
You might be able to get away with straight up F22 sizes if the pulley's aren't too much different in diameter. However its really sill to ask when all you have to do is measure the diameter with some string or something.
IE: 4 rib, 36" belt is all the info you need to bring with you to buy belts.
Originally posted by blackgoose View PostTry to be a little more detailed with the question.. I'm in Lancaster too.Originally posted by noahrexion View PostHow ever many ribs your crank pulley has (4) then that is the belt length you buy.
