The lugs that I used on the mag rims on my CB7 are getting really rusty. Are there any other better lugs that I can use on these mags that won't rust this bad?
Rusty lug nuts
Get a set of these, I think quality is good, also it covers the wheel stud from the elements.http://www.gorilla-auto.com/small-diameter-locks
Those lugs are universal lugs that all the Local car/tire maintenance shops use. They work and I admit I had a set a long time ago with my ADR rims back in the day.....but they are a thief's dream. Basically everyone has the same lug keys as you and if they really wanted to, they can jack your rims.
Another thing about them is that they can rust on the inside and break your lugs if it seizes. (Reason why I upgraded to project kics) They are high quality yet expensive but not everyone would want to spend over $130 for lugs but that means less chance of someone sharing the same lugkeys as you. I then changed to Mugen basic chrome lugs
Or run those lugs but add a very good security lugnut. Project Kics "Bull Lock" is supposedly good.Last edited by Warudakumi; 09-25-2014, 08:14 AM.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
I've got Rays lightweight aluminum lugnuts. I got them for free from a friend, I think they retail for like 180, but they're super light and have a heptagonal (7 sided) key lock that a run of the mill thief will not have. Mine are the older ones with slots cut in that only the key will fit over.
Not to mention you need a really thinwall 21mm socket to get these off, no regular 21mm will fit, so that is another line of security. Probably only Snap-on or Matco makes sockets that have clearances that low.
member's ride thread
91 Accord SE 176k
Originally posted by Restless View PostThese gorilla lug nuts aren't too bad.
http://www.brandsport.com/grla-21732.html
Originally posted by Warudakumi View PostThose lugs are universal lugs that all the Local car/tire maintenance shops use. They work and I admit I had a set a long time ago with my ADR rims back in the day.....but they are a thief's dream. Basically everyone has the same lug keys as you and if they really wanted to, they can jack your rims.
Yep, I picked up those lugnuts at a auto parts store when I first swapped the rims on the car. But I hate how bad they've rusted...
Originally posted by HCoupe View PostGet a set of these, I think quality is good, also it covers the wheel stud from the elements.http://www.gorilla-auto.com/small-diameter-locks
Thanks!
Originally posted by johnny_h View PostThose lug nuts are still "open" at the end and they'd rust just like the ones I currently have. I was looking for "closed" lugnuts that would fit my rims since the bolt holes are really narrow
Do you live by the ocean? Your drum looks like its WW2 wreckage. Use some anti seize on the threads (you will need to do this if you choose aluminum nuts), spray a little silicone spray on the outside of the lugs and they should stay decent looking.
You can use electrolysis to remove the rust from the lugs and paint them
http://www.cb7tuner.com/vbb/showthread.php?t=192590Last edited by illinois_erik; 09-29-2014, 10:44 AM.
I hate it when my nuts get all rusty.1993 SE Coupe MRT - 1992 LX Sedan MRT
Originally posted by illinois_erik View Postlook at the other gorilla lugs nuts that were posted, the "tuner" lugnuts. theyre slim profiled, and closed ended. the ones you have are cheap thats all.
Originally posted by johnny_h View PostNope, Im from Chicago. The drums are like that because the car sat for a few months while some mechanical things got fixed. Im planning on painting the calipers and drums soon.
