INT: Installing aftermarket steering wheel
    awesome write up
    been wanting to do this, chalk it up to reason number 456 why my car wont pass a state inspection lol ....
    a couple questions though:
    1. on the drivers side fuse box, what do you do here (after step one) remove a fuse?
    or is this tied into....
    2. ...this red dummy switch. is this located in that compartment, cuz if so, i might need to find one. and where exactly does this dummy switch plug into, the yellow coupling in pic one step two?
    CB7tuner.com Appearance Specialist - PM me with any bodywork questions
      Originally posted by '93accordse
      awesome write up
      1. yes you remove that fuse with that yellow cover on it.
      2. the red dummy PLUG is located in that little tiny cover of the compartment under the steering wheel. disconnect the airbag (yellow plug in the compartment) from the harness and put the dummy plug in its place.
      1cor10:31
      - 92 LX coupe
      - 96 EX wagon (sold)
        SOMEONE QUICK!!!!...90-91 putting on my momo hub/wheel. WHERE DO YOU GROUND THE HORN!!! i powered the horn using the plug right in the steering column but there is no ground for the horn there...only for the cruise. should i just ground the horn to the same ground for the cruise..?!?!?!...need help LMAO
          i grounded it to the actual hub bolt and it worked fine for me...you know, that huge bolt that holds the hub...loosen it a bit, slide the wire underneath it and tighten it back up again and that should be it...pic after youre done
          Originally posted by fizzbob7
          Originally posted by ACC0RD22
          So. Cal OUTLAWZ
            well i got the horn to work.
            but now when i turn the wheel i cant get the wires to return...so it have wires showing during driving
            i made a cutout on the side to allow passage for the wires didnt help
            so i just left the covers off for now. looks fine now but if i want to drive i have some wires sitting in my lap...not good.
            so im taking a break from the hot arkansas sun to think about how i can get this to work and still be clean without wires showing..
            i mean dayam wiring my shift light was a breeze compared to this. and that required me to take out the center trim, gauge cluster, and run wires through the firewall..this one was all inside the cabin but cant make it clean!!!!!! ARHG!!!!!
              i thought it was easy to install the horn for the non srs cars like the 90-91 accords...but dont worry, i have a wire hanging as well, i just gave it enough slack and added connectors so i could easily disconnect and tuck the extra wire whenever i want to show off a bit
              So. Cal OUTLAWZ
                its alot easier for 90/91.. but i still dont have a workin horn.. i already tried wiring it.. it just doesnt work right for me .. so i just use my chirper button...
                  yea overall the install was probably a lot easier than a SRS equipped car but im not talking about that part...im talking about making the whole thing look clean, like my MOMO wheel was supposed to be there the whole time.
                  im thinking im just going to wire up a button for the horn over where the cruise control is..that blank.
                    question...are quick release hubs any different to install than the normal aftermarket hubs?
                    I <3 G60.
                      the quick release hub is just an add-on and not an actual hub...it goes between the hub and the steering wheel and adds about an inch or two making the steering wheel closer to you
                      So. Cal OUTLAWZ
                        dang looks good...i love the guages and outline of the guages
                        My Ride17.34 @ 78mph with 260k on her
                          UPDATE**
                          I just did this and you DO NOT NEED TO SPLICE.
                          When you take off the steering wheel mount, there will be a piece of copper on your left that hangs down. It sort of looks like the negative end when you plug in a double A battery into something. You can just tap into that and with the extra wire, tuck into the column. The ground can be the bolt or just the hub itself. I just taped the ground to the inside of the hub.
                          ALSO, THE BLINKERS RESET WHEN YOU TURN, I don't know what you did but mine resets. I drive a DX btw.
                          SCORE 1 for the dx'sssss
                            you could keep the horn and blinkers working for a 90-91 but not for a 92-93
                            So. Cal OUTLAWZ
                              ftwwwwwwwwwwwww
                                I just put my steering wheel, Nrg #110 short hub and quick release on and i found a way to hook my horns up. When you disconnect the SRS system under the dash you will have the yellow connector still there. Put your wire (you will need about 24"inchs of wire) in the top left corner of the connect and at the other end of the wire put a piece of metal.(If u get the Nrg hub you will get a metal plate with a piece to slip on a metal connector). And the hub already has a ground on the hub. All you have left is to take out the srs bulb and your set.
                                "Know Your Rank"
