Failed Smog-"Ignition timing"
    This is my flywheel at TDC. Should it have this little "BB" indentation at TDC?
    If so then the timing marks might be covered with corrosion. If not than this might be an aftermarket flywheel with no marks.
    1992 LX Wagon
      Is that what you see when you use a timing light? I've never seen that mark before.
        That BB doesn't line up till I advance the light to about 30
        1992 LX Wagon
          Was the flywheel replaced? You said the transmission was, but do you know if the flywheel was as well?
          I'm thinking that mark is just something else on there, not used for calibration in any way. I wonder if the wheel wasn't put back on properly. Your 15 degree mark could be floating around somewhere else...
            I was under the impression that the wheel could only be installed one way. "deevergote" said he has never seen that mark before. I'm thinking maybe it's not a stock flywheel...
            1992 LX Wagon
              did you jump the service connector?
              I <3 G60.
                yes. I also spun the entire flywheel around slowly and didn't find timing marks. I think it's aftermarket. I'm going to call a shop today to get a quote.
                1992 LX Wagon
                  What is the exact procedure to check the timing on our cars?? Link or Something...
                  Thanks !!
                  Sorry for the steal!!
                  1990 Accord LX Sedan~Sold
                  1993 Accord EX Sedan~Sold
                  1995 Suzuki GSX-R 750~Totaled
                    We should have a DIY Timing Sticky!!!
                      you can get a crank pulley with timing marks on it. that would be much easier than changing the flywheel.
                      1990 Frost White EX Coupe F23A1 - PART OUT
                      01 DC4
                        The crank pulley marks are for Cam timing...I THINK!!
                          Looks like I will be replacing the flywheel. Any suggestions on a replacement? What else should I do while I'm in that area? I assume replace the belt of course?
                          1992 LX Wagon
                            So this entire thread I have been calling the flexplate the flywheel. I guess when they replaced the tranny they installed a flexplate with out good timing marks. I will go to Honda friday and see if I can get anywhere.
                            1992 LX Wagon
                              Ah, so you're auto. I've never done the timing on an auto, so it's entirely possible that the mark you see is correct... I can't say for sure, since I've never done it.
                              And yes, the crank pulley is not for setting the ignition timing.
                                yeah I should have been more specific! I'm wondering how detailed of a job it will be to replace this flex plate.
                                1992 LX Wagon
