Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech
Old 03-27-2018, 05:20 PM   #1
92smokeaccord
92smokeaccord seems to have made some friends! 92smokeaccord seems to have made some friends!
Esp mount bushing replacement
Hey peeps. Just got my hands on a set of used esp mounts and they have 70a urathane bushings. Anybody know where to get replacement bushings. These are going in my turbo coupe I want to get the stiffer 95a ones or as stiff as I can get them. Pic well because why not
my new turbo build
92smokeaccord is offline   Reply With Quote
Old 03-27-2018, 05:54 PM   #2
Raf99
Originally Posted by 92smokeaccord View Post
Hey peeps. Just got my hands on a set of used esp mounts and they have 70a urathane bushings. Anybody know where to get replacement bushings. These are going in my turbo coupe I want to get the stiffer 95a ones or as stiff as I can get them. Pic well because why not ....
I imagine ESP themselves could probably help ya out. They are on here and on FB.
Old 03-27-2018, 06:27 PM   #3
92smokeaccord
Sent a email no reply. Prob just busy. Figured I’d ask here seein as they are like the main supplier for aftermarket mounts for cb.
my new turbo build
Old 03-27-2018, 07:54 PM   #4
illinois_erik
Talk to John..but theres always
http://www.polybushings.com/pages/bushingsbysize.html
Thanks to [CP] Mike..
When I replace mine, I think i will get rid of the gap between bushes in the center of the housing, they dont touch; have maybe a 10mm gap.
Old 03-28-2018, 02:44 PM   #5
CyborgGT
CyborgGT is cool... so far.
I'm not seeing any urethane stiffness ratings at that link? I'm wanting to go softer on my ESP mounts, and match HASport's 62A "street" stiffness. I'll probably end up contacting ESP, but still, it would be cool to be able to get replacements that easily for any other bushings on the car I might want to swap out.
Old 03-28-2018, 05:50 PM   #6
illinois_erik
Me either, they have an email and phone number, im guessing theyre 70A.
The example link was the only one I could remember off the top of my head where you can purchase based off of dimensions vs application, however if you really dug you can get what you needed from 4x4 suspension fabrication sites, there was a really good one I found long ago but my brain drew a blank to even find them again.
For something softer than 70a you might want to venture back into rubber bush territory, their claimed "62A" sounds a little hyped up and is just a bit over what a hard rubber bushes durometer rating is. (you know looking cool vs function of having poly opposed to rubber..dunno)
Luckily these days almost anything can be found online with enough time, Id bet youd be pretty surprised to find that ESP just buys some generic bulk bushes and theyre nothing exotic and they remain kind of hush hush about their "trade secrets". I inquired flat out about pricing on some new heim joints for my traction bars, as one inboard one has developed some slop and clicks when I drive and was met with emailing etc etc, I can find the exact spec'd and probably better made ones on 4x4 fab sites.
Old 03-28-2018, 10:27 PM   #7
CyborgGT
I was just under the impression that polyurethane holds up better over time; being more resistant to chemicals, weathering/heat, and the constant flexing a bushing experiences over its lifespan, so I figure even a urethane as soft as OE rubber will still last much longer. Longevity was why I bought mine in the first place, but the 70A is horrible in the winter.
Old 03-29-2018, 12:26 AM   #8
illinois_erik
probably with todays aftermarket rubber, I had OE style rear control arms go bad in a year, but even my esp mounts, the holes are starting to wallow out, theyre egg shaped now and 4ish years old. But something quality made (good luck finding it these days) like the original rubber mounts, they lasted 20 years at least..and mostly failed from dry rotting. Have you heard of "303" rubber protectant, or the mint oil/alcohol trick, that and some OE mounts might make them last a good while. Petroleum will kill poly pretty quick too hence the special silicone based lube for suspension bushes.
Old 03-29-2018, 04:32 AM   #9
CyborgGT
HASport seems to take their urethane formula seriously:
http://forums.clubrsx.com/showthread.php?t=788800
I just really wish they made all three mounts for our cars. I don't get their logic in leaving out mounts because they don't feel they're important. A poster in that link backed up concerns I'd been having about leaving one mount soft and transferring the motion to that weakest link rather than spreading the load evenly. I know the torque isn't pulling up and down on that transmission mount with a transversely mounted engine, but there's still a twist in there that I imagine might become diagonal when the other two are stiffened.
Old 03-29-2018, 09:56 AM   #10
92smokeaccord
Well I ended up getting a reply from esp and they only carry 70a. He said he uses it in his 500+ hp car and all that. What I do t think he understands is that I just want what I want. Doesn’t matter the reasons. I want the stiffest I can get I have seen few people get new inserts with higher stiffness just want to know how. And where they got them from. I may have to call polyurethane company with measurements and see what I can get.
my new turbo build
Old 03-29-2018, 10:01 AM   #11
illinois_erik
pretty interesting what HASport had to say. Looking up their replacement bushings, I almost bet they would be a drop in based off my eye-crometer =]
its only a 25$ gamble too.
Old 03-29-2018, 03:03 PM   #12
ESP-net
CB7tuner.com approved seller
ESP-net is cool... so far.
Send a message via AIM to ESP-net
Hey guys Email Us. ExplicitSpeed360@aol.com
As far as polyurethane yes it is the way to go for Motor Mount inserts. For suspension parts I use and recommend harden rubber. I know cost a little bit but I use HardRace.
Our inserts are only to us to use. We pay for molds to be made. If they are produced without our knowledge it is illegal from supplier. We solely have the rights to the inserts. No Hsquirts are different size poly. Much cheaper than what we pay unfortunately. Yes we have shopped around numerous times. The inserts are made to have a gap in the middle. There is no issues of doing this
I do not carry much spares we are small potatoes when we order it is for current orders. Sometimes I may have 1 set to spare. I have 4 Black inserts at the moment to spare. $60 Shipped US or $75 Shipped for Set of 6 if have 6. 2 per mount.
As far as insert grade... some Co's start off with 60 too soft. We use 70. 80 and 90 is race only lot of vibration. 70 is good for just about everyone upwards of 600++ whp. Front Torque Mount Kit on our Traction Bar System will take over and aid from there. I run 70s on my 500 hp H23V turbo crx and dc2 with no issues at all. Dc2 mounts lasting 10 years and 2 diff cars and is at 500 hp. I have people running our Mount Kits with 10 years on inserts. Warmer areas the Polyurethane can shorten its life span.
All we have ever used in our Mount Kits is 70A polyurethane. Whether was Black or Red was same grade. Black is only color available in last 6 months or so. Makes it easier.
Our inserts have been on numerous vehicles at over 700++ whp. Highest to date may be 850 whp H22 CD Accord.
Explicit Speed Performance
www.ExplicitSpeedPerformance.net
Custom Engineering and Fabrication
Motor Mount Kits, Traction Bar Systems, Solid 2/3/4 Pt Strut Bars, F22/H22/H23 Alternator/Tensioner Kits and much more...
ESP-net is offline   Reply With Quote
Old 03-30-2018, 12:15 AM   #13
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
"wanting what you want" is all well and good, but "stiff" doesn't mean "fast". it just means uncomfortable.
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 03-31-2018, 07:07 AM   #14
92smokeaccord
I know stiff doesn’t mean fast. Fast means fast. Just wanting what I want is all it really is. The car is on its way from a capable daily driver to a track/street car seeing as I have my 4 dr now for daily activities. So far she’s about a month away from being caged,cut and lexan windows so what’s a set of extra stiff mounts. Like I said just cause I want it not because it’s “faster”.
my new turbo build
