Old 10-18-2018, 03:34 PM   #1
Harriers Wake
CB7tuner Member
Location: Albuquerque NM currently, Pasadena CA born and raised.
Harriers Wake is cool... so far.
Harriers Wake : 1990 Accord LX
"SKELETOR"
ENGINE
Stock F22A1
Ebay H2U5
Custom Welded piping from Cat-back
Vibrant Stealth Dual-exit Muffler
EXTERIOR
Dirt McGurt stock paint
93 SE decklid
INTERIOR
Stock
SUSPENSION/WHEELS
15" Maxxim Screech (Equip knockoffs)
Hankook Ventus V2's front
Bald Fuzions rear
93 SE Rear Disc conversion
AUDIO/ELECTRONICS
Stolen radio
Inop stock speakers
Right now there are a ton of Electrical issues, some damage to passenger side front, the brakes are shot and I'm pretty sure the Tranny is about to eat itself. Again. She's got a long way to go.
FUTURE PLANS
Closed-deck/Low-comp/Treadstone boosted H22
Chipped/Socketed P28 with Hondata V300+
KStuned tensioner kit
Wiseco Pistons
Eagle Rods
ARP Studs
Walbro 255
High-flow Injectors
Mishimoto external Oil cooler
Battery Relocation
M2B4 LSD tranny with Accord 5th gear
Championship White paint/Black moldings/bumpers/lips/black out all chrome
Zenki One-piece headlamps/Blackhoused/Projector retrofit/black out chrome lip
Kouki Sedan Red/Clears
All Intersection lights
Kouki Front bumper
Greddy BB6 Front lip
CG coupe side skirts
Mugen style ABS rear lip or Custom Diffuser(not sure which)
OEM flushmount
Jumdoo 50mm Classic Flares
Astra Hammond Coupe rear louvers
Stock Grey Coupe interior
Weld-in Cage
S2K Cluster
Mugen/Recaro MS-Z Semi-bucket seats/Planted bases
Prothane full Poly kit
Eibach Pro-kit Springs
Koni Sport yellows
ESP 3-point Upper strut bar
ESP engine mount kit
EX/SE rear sub-frame swap
ST swaybars
Cheddas LCA's
EBC Ultimax rotors and Red stuff pads
Braided brake hoses
16x8+16 4x114.3 U.S. Wheels 022 Daytona Drifters White/Polished Lip
225/45R16 Yokohama A052 ADVANS
Stock Acura Radio
Fix all the Electrical problems
Apologies for the garbage cell-phone pics
Harriers Wake is offline   Reply With Quote
Old 10-18-2018, 06:11 PM   #2
Grumpys93
Contributing Member
Excuse my ignorance but what are Zenki headlights and Kouki bumpers? I’ve only heard those terms when it comes to 240sx and their body style.
__________________
~Nick~
Old 10-19-2018, 08:06 AM   #3
Harriers Wake
CB7tuner Member
As it was explained to me the rough translation of Zenki is "Before something" and Kouki is "After something". It's been used as slang specifically pertaining to the S14 Silvia due to the difference in headlights stemming from the mid-generation facelift, but it's technically relevant for any model of car that has such a mid-generation facelift. Since CB's had a fairly subtle, if not extensive face-lift between 91 and 92, I guess you could say Zenki is a nerdy way to say 90-91 and Kouki is the same for 92-93. It works for just about any car but the Silvia cats will act like they own the copyright sometimes.
Old 10-19-2018, 03:38 PM   #4
CyborgGT
CB7tuner Member
CyborgGT is cool... so far.
I don't think that combination will work with all-OEM parts. The 90-91 headlight lens has a curve higher up in the glass than the 92-93, so the grille is flat for the former and has a curve roughly mid way up for the latter. Mentioning the grille is important because if you want your grille to match your headlights, you also need the matching bumper, because the 92-93's grille is shorter and the bumper compensates for that with a raised ledge. You could dodge that with a G-Square grille, if you're into that look. Or I suppose shave the ledge off the 92-93 bumper for the 90-91 grille to fit, if you're careful in making a straight cut.
90-91
92-93 (this car actually has your listed combination of early lights with later grille+bumper; you can see how it doesn't match up)
G-Square grille
__________________
Slowly but surely... and gunning for that NA list!
Old 10-19-2018, 09:48 PM   #5
AccordWarrior
Guy Smiley
AccordWarrior is very helpful AccordWarrior is very helpful AccordWarrior is very helpful
Quote:
90-91
G-Square grille
That was my immediate thought as well. I had a 92-93 bumper on my car for winter with a 92-93 grille and 90-91 headlights and it didn't fit great. I had originally done the 92-92 bumper with the cheesy projector 1 piece headlights for giggles for winter but they were so dim the car was undriveable.
The Laurel Blue Metallic really brings me back. Sometimes I want to do a second round, but the memories are better than the reality.
AccordWarrior is offline   Reply With Quote
Old 10-22-2018, 10:40 AM   #6
Harriers Wake
CB7tuner Member
90-91
G-Square grille
I didn't realize the later bumper had the lip to fit the later grill but I'm ok with shaving the bumper to fit the 90-91 grill, I feel like the 90-91 lights and grill have to go to together. Coincidentally the blacked out lip around the headlamps I'm planning to do came from the second pic you posted. The first time I saw that photo I knew I had to do that to all of the chrome on the car.
Old 10-23-2018, 04:33 AM   #7
CyborgGT
CB7tuner Member
All of the chrome on the car? I'm definitely interested in seeing how that comes out. I think the chrome trim around the glass dates the car a bit, and there are little things I'd like to try to bring mine out of the '90s, but I also worry about blacking it out looking cheesy. Could go either matte or gloss with the black, or even try body color, or a combination of a couple of those depending on the specific pieces in question... I've got some experimentation ahead of me for sure.
__________________
Old 10-23-2018, 01:21 PM   #8
Harriers Wake
CB7tuner Member
I'm fairly certain a chrome shop could do it but I feel it would be fairly expensive. If a cheaper alternative exists that looks as good, I'd rather just research that and try it myself on some junkyard trim to see if it works.
