Steering wheel knocking
    When I am driving and I turn to the left there is a knocking noise in the steering wheel and it vibrates really bad
    has not been going on that long but I am worried that something could be about to break while I am driving
    Help!!!
    Do this:
    http://www.cb7tuner.com/vbb/showthread.php?t=119467
    Can you make a video of the sound?
    MRT
    sneaky motherfucker
      Drive Axel noise?
      Check the Upper and Lower Ball joint.
      Something the Universal Joint in the Steering Collumn are getting loose, check that to. Or even the bolt that holding the Pinion , its a 12mm bolt.
