h23a pump gas dyno
    h23a pump gas dyno
    not sure if admins need to move this.
    H23a blue top bottom end (stock)
    KStuned balance shaft delete kit
    H22A RLZ outlaw head
    K2H adapter
    RBC intake manifold unported
    70mm tb
    PLM RMF REP
    3" exhaust
    93 Octane Pump Gas
    Tuned by Me
    Gsr Transmission (h2b)
    250whp/180wtq
    dunno if this needs to be moved since it isnt a CB7, just figured the horsepower figures would be interesting for you guys to see.
    Praise The Lowered...
    So I can swap an f22 crank and rods into an h22a and make 250 ish whp? Hmmmmm.
    YouTube Clicky!!
      You sir did not read correctly.
        x2.
        those are badass numbers! i bet that thing hauls ass.
        COUPE K24
          What am I missing? The only custom things I see are the headwork and tuning. Everything else can be purchased directly.
          H22a + 95 mm crank + f22a rods + type-s pistons = ~12.1:1 compression H23 block? or is that way off...I've never built an engine before, but I'm going to redo the math on this. I would like to get similar numbers to this engine. (Beautiful curve btw WiKKeDV16)
          YouTube Clicky!!
            The engine is a h23a its a factory dohc vtec engine. Im waiting to swap one in as we speak. The car is also h2b (h series engine b series transmission). Typically more power is put down with h2b setups as opposed to a h series transmission set up. Im impressed by the numbers on pumpgas as well though that ported head must be a work of art.
              My POS Laptop almost made me kick you in the nuts, I'll figure it out but good job.
              '94 JDM H22A: 178whp 146wtq
                I'm thinking there is black magic in the head. I've always liked the H23a. I also recently learned that Rosko Racing makes a prelude h2b kit. Pretty cool.
                YouTube Clicky!!
                  Yeah, if that's a stock cam'd H23A, that head is black magic.
                  '98 Prelude resto/mod thread
                    My apologies guys..!!! Totally didn't see that I did not put the cams! Lmao
                    Pro2s skunks
