Stiff shifting manual tranny in temps < 40F
    Over the last few winters my 90 accord EX has developed a problem with the manual transmission shifter when the car is cold. The shifter moves easily in the North-South (front-back) direction, but is extremely stiff in the East-West direction. I mean that I have to really lean on the shifter to get it to move. It stays stiff for the first 15-20 minutes of driving, gradually loosening up to normal movement when the car is fully warmed up. After the car is warm the shifter is easy to shift and has not a hint of a problem.
    Last winter I drained and refilled the transmission with the newer Honda MTL. It improved the overall performance of the transmission, but had no effect on the cold shift problem.
    It kind of feels like a shifter cable problem, but I was hoping to find some other folks talking about this problem (and the solution) on the forums before I pulled it all apart. I have not found anyone describing this same problem.
    I live in Atlanta, so this problem only occurs for a few months a year. But I would really like to solve it. Please give me your ideas....
    bad shifter cable.or ur cable coating cracked and u got water that is freezing inside the line.
    my new turbo build
      Could also be your fluid. Change it for synthetic Honda MTF or GM Synchromesh. They both work very well (many feel the GM fluid works better, actually)
      My car was similar when a shop put gear oil (far too thick!) in my transmission.
        Look under hood, find the tranny shift cables (two). Have someone shift car East-West problematic direction, isolate cable that moves in that direction. That is your problem.
        End result, you should just replace both, comes as a set. Get new or if on budget, good used from a member/junkyard. If from JY, test in vehicle before removal obviously.
        Great job in your question and description, THANK YOU!! Too many do not and still expect help.
          And then you get the guys who somehow miss the whole part about the fluid change already being done... like me.
          The fact that it changd as the car warmed up reminded me VERY strongly of my gear oil experience.
            Probably due to you being changed into a Lego Man?
              Yeah, very likely... all that plastic hair reduces brain function!
                i had the same problem on an integra i used to have. everytime i went out to start it in the winter, the shifter would be super stiff. but when i left it and let it run, after it warmed up it was normal. i always thought it was the fluid and i still do being as my integra had a cable clutch and this guys accord has the same issue. my vote is fluid
                  Thanks for the suggestions. I guess I need to go ahead and plan to swap the cables. Anyone that has done this want to give a quick summary? I don't think the Haynes manual covers this (I know, I know, buy the real Honda shop manual). I really just want to know how much stuff I have to remove to get to get the job done.
