Straight cut transmission
    Has anybody put one of these in? When I eventually switch I think it would be cool. If so, where did you get it and how much did it cost?
    MRT
    sneaky motherfucker
    Dogbox. They are custom made in most cases, and VERY expensive. Also not at all suited to a daily driven car. That's a race-only unit. I've heard of one or two people on here that have had them (I think only one was in a CB) and even those guys said they would never drive their car on the street with it.
    They are strong, and take lots of abuse. If you plan on making a 700whp drag car, you'll want one. Otherwise... it's far too much for a street-driven hobby car.
    Two well known manufacturers of full race transmissions are PPG and MFactory. Both only show applications for B and K series engines on their sites, but apparently they used to make H/F stuff. You may be able to contact them for information.
    The prices I saw on the sites started at $4000. I'm quite sure that some additional modification will be needed. You would probably need to convert to a rod shifting setup, rather than the H/F cable setup... that won't be cheap either.
      Well never-mind then, I only wanted it because it sounded cool...
      MRT
      sneaky motherfucker
        Yeah, that's the WORST way to plan mods for your car
          At the risk of whoring.....AAHHAHAHAHAHA, that's hilarious but so ridiculously prevalent and true!
          My Member's Ride Thread
            Drive in reverse then, lower your miles while your at it...
            wat?
              It's like those threads where people say "I want a blow off valve... what do I need to install one on my bone stock engine?"
              They have no idea what it does. They just heard someone mention it on a forum and they want to be cool like the big boys.
              I'm going to start talking about how cool a vasecotmy is, and see if I can get anyone to post asking what it takes to get one!
                Well, at least it would be unique!
                I got the idea from here:
                http://www.youtube.com/watch?v=eSJ-HzNWJGM
                Just imagine having friends with you, or even driving by someone at 15 mph!
                It'd be hilarious, but not $4k hilarious
                Maybe it's time to redo your sig...?
                MRT
                sneaky motherfucker
                  increase the tension on your timing belt, it'll give a supercharger whine.
                  I <3 G60.
                    I have to admit, I also thought about this:
                    http://www.turbowhistler.net/exotic-cars/exoticcar9.htm
                    I saw it on top gear.
                    As long as we're on the subject of transmissions, has anybody put in a 6 speed?
                    MRT
                    sneaky motherfucker
                      Yes, the few that have done a k-swap. There is not a 6speed that will bolt up to the f22 and cb7 without adapter plates and custom mounts/axles. It isn't just a simple "putting in a 6-speed".
                        That video made me poop a little bit.
                        Unless you're planning a wicked motor build, that tranny would be a waste. But it would sound wicked awesome...
                        Form.Follows.Function
                          thats sound like fun, no more kids .... im cool wit that...
                          Ride List
                          2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
                          newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
                            Take out your wheel bearings, fill them with dirt and put them back in. Now you sound cool like a race car y0.
                              No they don't, it sounds like a grinding/roaring noise - like a muffler rubbing. It's really annoying.
                              It's working already!
                              MRT
                              sneaky motherfucker
