Cruise conrtol not working
    Hi, ive been doing my research and a fair amount of google-ing and i still cant come to a conclusion as to why my cruise control wont work. As a few post have mentioned, the green light on the button should illuminate green, so far it does, but when i press on the "set" button on the steering wheel and lift my foot off the gas pedal, the car does not maintain speed (above 30 mph). ive checked my pedals and no sensors seem to be working abnormal. Just for the record i do understand the bassics of cruise control, and i understand that when activating cruise control, the pressing of the clutch or brake can deactivate cruise control.
    Here are my specs:
    1992 honda accord LX
    5 speed manual
    F22a stock motor
    210,056 miles
    Thank you in advance and i appologize if this thread is a repetition of a previous thread i might have missed.
    Check your vacuum connections on the diaphragm. The little cylindrical looking thing with the long tail leading to the firewall on the driver's side of the engine bay.
    YouTube Clicky!!
      If you lift your foot immediately upon pressing the button, that might be an issue. Try hitting the "set" button and holding your foot steady on the pedal for a two seconds.
      Could be a bad switch, bad control unit, problem with wiring. Do you have a wiring diagram for the circuit?
