I was going to post something long but here's the tl;dr version.
My OEM Honda wiper on the driver side hits the side of my windshield when in use. I tried re-positioning it, but the blade is either too low or too high in resting position. It seems there's some give on that motor, causing the blade to hit as well as not allowing the blade to make contact with the windshield as it returns from it's wipe.
Is there some trick to positioning the arm, or is it worn & needs to be replaced? I already spent $95 on the Honda blades, and it'll cost another $90 for a new arm from my dealer.
Thoughts? Thanks!
Thoughts? Thanks!
