Go Back   CB7Tuner Forums > Parts & Performance > Appearance > JDM
Thread Tools Rating: Thread Rating: 8 votes, 4.00 average. Display Modes
Old 10-12-2004, 02:15 PM   #21
shawn.hayden
Accord of the Month: August 2006
shawn.hayden is cool... so far.
ya but the offsets are way off.... you have to do a little customizing to make em fit (ex: spacers)
OS^e
1993 Honda Accord LX Coupe
My Members Ride's Thread
StickyDilJoe: "JDM may be a fad, but making your car look like shit... thats forever"
shawn.hayden is offline   Reply With Quote
Old 10-18-2004, 08:42 PM   #22
CB7Tuner915
CB7Tuner915 is cool... so far.
where can i buy tha 96 ITR rims?
H23?
CB7Tuner915 is offline   Reply With Quote
Old 10-18-2004, 09:39 PM   #23
uncle_el
Moderator
uncle_el is cool... so far.
members on this board or others (honda-tech, jspek.com)
www.ebay.com
www.passwordjdm.com
uncle_el is offline   Reply With Quote
Old 10-20-2004, 08:31 AM   #24
uncle_el
Moderator
here's a link to a good quality set of spacers. both 5mm and 10mm spacers are sold the guy knows wheel issues like the back of his hand (check www.vipstylecars.com, user name onetonvip).
someone should get try those advans!
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old 10-20-2004, 08:02 PM   #25
shawn.hayden
damnit if they weren't rear wheel drive wheels I would probably be all over them....
17x8 in the front 17x9 in the rear, you'd DEFINATLY have issues with fitment in the rear.
OS^e
Old 10-20-2004, 08:20 PM   #26
uncle_el
Moderator
idk... i need to learn more about wheels.
the only thing i know about rear wheel drive cars is that they tend to be able to accept wheels with negative offsets (thus allowing for crazy lip if desired).
i would think the only fitment issues in the rear would be that the wheels would stick out beyond the body.
Old 10-20-2004, 08:48 PM   #27
93accordEX
93accordEX is cool... so far.
Send a message via AIM to 93accordEX
some bad news... the problem with lower offset wheels is that they stick out too far. adding a 10mm spacer to a +32 offset wheel = a +22 offset.
HSHO #3
93accordEX is offline   Reply With Quote
Old 10-20-2004, 09:54 PM   #28
uncle_el
Moderator
damn, you're right!
the higher/more positive/further from zero the offset, the closer it is to the vehicle.
the lower/more negative/closer to zero the offset, the further it is from the vehicle.
a spacer reduces rim offset (i.e. makes it lower/more negative/closer to zero) and thus pushes it further from the vehicle. i forgot that you subtract, not add when calculating the use of a spacer.
edit: some more info i found on offset for those interested-
Offset is the location of the flat mounting surface of a wheel relative to the wheel's centerline. Negative offset means the mounting surface is toward the center of the car, positive offset means it is toward the outside of the car, or the wheel is "pulled in" toward the center. Offset affects many things other than just whether the wheel has the appearance of "sticking out" past the fender. The wrong offset can cause rubbing problems when the suspension is compressed or the wheel is turned. Offset affects the steering geometry's scrub radius, possibly leading to problems with torque steer or self-centering characteristics. Offset also affects the suspension's motion ratio, which directly determines the effective spring and damper rates. Potentially, in a very heavily loaded vehicle, or with extreme changes in offsets, wheel bearing life can be affected, but this is more often talked about by truck people than by small car enthusiasts. It is very, very important that the proper offset wheels be used.
The formula to find offset located above the photo is incorrect. The correct formula is: Offset = Backspace - (width/2)
While not directly a matter of offset, brake caliper clearance is a related issue. If you have, or plan to have big brakes on your car, be sure that your wheels, or the wheels you are going to use, will fit over the calipers. Spacers are available to solve the problem if they don't, but it is best to get a wheel with enough dish to meet your offset specs and still fit your brakes. Consulting the wheel and brake manufacturers ahead of time is wise. Many aftermarket brake companies even have templates of their brakes available that you can easily check against any wheel.
source: http://www.sportcompactcarweb.com/te...cc_wheelguide/
edit 2: though in the end, using a spacer would ensure caliper clearance... but it would probably look a bit funny. or would it? bimmer and v dub guys/gals run wheels that stick out just a bit, and it looks cool:
beauty is in the eye of the beholder. maybe it just takes one of us to begin the journey...
Old 10-20-2004, 11:48 PM   #29
xScott
xScott may have said something they shouldn't have...
I think im going to get theses...
xScott is offline   Reply With Quote
Old 10-21-2004, 09:42 AM   #30
uncle_el
Moderator
i created a thread about rwd wheels on a fwd car:
http://www.cb7tuner.com/vbb/showthre...threadid=12533
i guess those super advans may be a bit too wide for the rear, as 93akkord/shawn.hayden thought... or are they?!?!!?
edit: cb7deathride, i thought you said no more jdm items?!?! g square wheels to go with a g square grill?!?
Old 10-21-2004, 06:03 PM   #31
xScott
Something like that. I want wheels, dosent matter if they are JDM or USDM or EDM or whatever.
Old 10-22-2004, 02:28 PM   #32
shawn.hayden
I dunno, those could be made to fit, but being 9 inches wide in the rear seems like it'd take a lot of work to keep them from rubbing (alot of negative camber, and rolling the fenders would be things you would HAVE to do.)
I'll try to find the picture I've got of the EK Civic hatch that has some NASTY rear negative camber... I didn't think it had RWD wheels, but now that this has come up, it's the only thing I can figure... they looked like Gabs though.. hmm I'll look for it and post it up.
OS^e
Old 02-16-2005, 09:36 PM   #33
uncle_el
Moderator
another site, thanks to 4drcord:
www.memoryfab.com/wheels
http://memory.sunpower-usa.com/used/
Old 02-17-2005, 03:14 AM   #34
shawn.hayden
ya I've been checking out memoryfab for awhile very good site to spot wheels! (especially the Regamaster Evo's that I want )
OS^e
Old 05-11-2005, 11:53 AM   #35
uncle_el
Moderator
another place to find wheels:
http://store.yahoo.com/yhst-14083816...mhatofius.html
edit:
www.jdmland.com is the same site
Old 05-11-2005, 12:02 PM   #36
ZigenBallZ
CB7Tuner Member
ZigenBallZ is cool... so far.
Send a message via AIM to ZigenBallZ
Originally Posted by uncle_el
look at all the CP-R's & CP-F's... :drool:
awesome link...
RIP Lifsatrip7
ZigenBallZ is offline   Reply With Quote
Old 01-18-2006, 08:22 PM   #37
OnE eYe GuY
OnE eYe GuY is cool... so far.
Send a message via AIM to OnE eYe GuY
my friend has a 240 and we swap wheels all the time. no problem with offsets. an 86? i dont know really. i always see my friends with 0 offset, some serious dish.
Nitrous is like a hot chick with an STD. You know you wanna hit it, but your afraid of the consequences.
My Member Thread
^ Updated pics 3/3/06
OnE eYe GuY is offline   Reply With Quote
Old 03-20-2006, 10:19 PM   #38
uncle_el
Moderator
http://www.rrr-game.com/
a sister company of upgarage.
Old 06-25-2006, 07:14 AM   #39
Grant8311
Grant8311 is cool... so far.
Send a message via AIM to Grant8311 Send a message via MSN to Grant8311
http://www.jspec.com
http://www.pandagarage.com
http://www.wheelchoice.com
http://www.rbmotoring.com
Grant8311 is offline   Reply With Quote
Old 06-25-2006, 10:13 AM   #40
SOHC on dis
SOHC on dis is cool... so far.
JDM Yo!
I bought mine from RB.
My whips!
97 eliteS 50cc sold
90 CB coupe lx h22 turbo(ITS GONE!)
93 CB 4dr ex/se
85 Hilux 4x4(chevy 350)traded
80 Hilux 2wd still got it
73 Opel GT garage queen
92 cx hatch b16a ran into the ground
93 si hatch b16a type-r trans parted out
92 dx hatch fully built GSR "huge" fmi sold
09 4dr 4x4 Tacoma small lift daily beater
93 dx hatch b16a2 (old team rice car) was free!
SOHC on dis is offline   Reply With Quote
