Go Back   CB7Tuner Forums > Parts & Performance > Appearance > JDM
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 02-08-2007, 08:54 PM   #61
accordztech
accordztech is cool... so far.
Send a message via AIM to accordztech
Here is how to make the h4 funtion as a high and low beam working together with the h1 bulb, and its not on all the time just like it should be.
Retro!
Hater
accordztech is offline   Reply With Quote
Old 02-09-2007, 10:25 PM   #62
Blk EX Coupe
Blk EX Coupe is cool... so far.
The way you wired it up, the upper and lower filament gets power on the H4 bulb, that is what I wanted to avoid. But I can see through your diagram how you accomplished both H4 and H1 high beams.
I believe the h4 bulbs is power, low ground, and high ground.
Blk EX Coupe is offline   Reply With Quote
Old 02-10-2007, 02:55 AM   #63
accordztech
power, low ground, high ground is right. hehe i thought it was power, low ground...and high power but obviously it didnt work lol!
why didnt you want the high and low to get power? mine is separate, if i turn the highs on the high beams actually turn on the h4 and if i turn it off it just is standard.
Retro!
Hater
Old 02-10-2007, 10:36 AM   #64
Blk EX Coupe
I'm talking about just the on H4 bulb. On cars that have h4 stock its upper or lower filament, but not both at the same time even though both would give you great output. It makes the bulb run way too hot, and reduces it's life. If I was going to run the H4 bulb instread of HID's I would have wanted some nice Polargs which don't come cheap.
Old 02-11-2007, 03:39 AM   #65
accordztech
you do know i wired it up normal right? aha. like low beam its only low beam, and high on the h4 it is the high on that bulb...rite? i dont use the high beams for more than 5 minutes at most anyways and also i put a higher upgraded harness =)
Retro!
Hater
Old 02-12-2007, 12:28 AM   #66
Blk EX Coupe
They do? I can't see how through the diagram, but I'll take your word for it since I don't have jdm headlights anymore. Maybe one day when I pick up a new set I can use this
Old 02-12-2007, 03:05 AM   #67
accordztech
hahah yea they do.
its hard to explain unless you understand how a relay works, its just like a mini switch.
85+86 is the switch. one is always going to get positive and the other is going to get negitive allowing whatever is at pin 30 to go to pin 87. think of it as a door, 85+86 will open the door for the pin 30 to go to the 87.
in this case, i used the positive and negitive from the high beam (it only does pos and neg when the high is on and not when its off) to trigger the switch. pin 30 is grounded to the high beam ground, so that signal goes directly to pin 87 as a ground to turn on the h4 high beam.
Retro!
Hater
Old 05-01-2007, 12:24 AM   #68
lx-accord
lx-accord is cool... so far.
Send a message via MSN to lx-accord
i know this may sound dumb but has anyone convertered the h4/h1 to 9005/9006 due to the fact i already purchased hids for my 90 accord ..... i might purchase a set of jdm 1 piece headlight for my accord but i now realized that there h4/h1 is there anyway around this? custom fit the rear socket to 9005/9006?
lx-accord is offline   Reply With Quote
Old 09-20-2008, 02:50 PM   #69
KRIS05VVTi
KRIS05VVTi is cool... so far.
Send a message via AIM to KRIS05VVTi Send a message via MSN to KRIS05VVTi
nice write up
Purchased from: 90-JDMCB7, cb95spd, 92_dr_p, ukaccord92, slammed4thgen, 93a-lude, h22anow, cb7addicted, H22WAGON93, tonymontana1204, agol, Joshy
Sold to: di2accord
KRIS05VVTi is offline   Reply With Quote
Old 10-08-2008, 08:36 PM   #70
91-accord
91-accord is cool... so far.
So I've got a pair of chrome trimed JDM headlights and I'm not quiet sure how the wiring is done. How can I convert my 9006 & 9005 harnesses to h1 & h4 harnesses?
91-accord
watch quick clip: 10-80 mph
91-accord is offline   Reply With Quote
Old 10-09-2008, 08:27 PM   #71
91-accord
hello???
91-accord
Old 10-19-2008, 12:41 AM   #72
91-accord
BTW, I'm still waiting for an answer. thank you
91-accord
Old 10-19-2008, 01:20 AM   #73
SE_DynamiK
SE_DynamiK is cool... so far.
Send a message via AIM to SE_DynamiK
http://passwordjdm.com/PasswordJDM-B...-P1768C50.aspx
SE_DynamiK is offline   Reply With Quote
Old 10-19-2008, 11:03 AM   #74
91-accord
Originally Posted by SE_DynamiK View Post
thank you so much. I think I'm just gonna go ahead and purchase a regular harness for an h1 and h4 and hook it up that way.
91-accord
Old 10-21-2008, 01:02 AM   #75
SE_DynamiK
they sell all 4 right there in one package.
i bought myself a set; saves a hell of a lot of trouble.
i think it came up to ~45$ shipped
Old 11-30-2008, 12:33 AM   #76
benjerman112
benjerman112 is cool... so far.
yea and it makes it so much easier
could a 100w bulb be safley be used?
Freedom Is Not Free
U.S Army 02/08 Medically Discharged
benjerman112 is offline   Reply With Quote
Old 04-02-2009, 01:55 AM   #77
ECalvo31
ECalvo31 is cool... so far.
Send a message via AIM to ECalvo31 Send a message via MSN to ECalvo31 Send a message via Yahoo to ECalvo31
Is there anyone out there that knows where I can get a "insight DRL module" at?
"The greatest loyalty in life is, above all, to thine own Self be true."
Facebook
MySpace
My Ride
ECalvo31 is offline   Reply With Quote
Old 04-02-2009, 02:41 AM   #78
accordztech
i got mine on ebay
Retro!
Hater
Old 04-02-2009, 02:49 AM   #79
ECalvo31
Originally Posted by accordztech View Post
i got mine on ebay
What did you put in the search link? Because I did that and nothing came up. Thanks for the answer back.
Facebook
MySpace
My Ride
Old 04-02-2009, 02:51 AM   #80
accordztech
perhaps they dont have it anymore. this was like 4 years ago.
Retro!
Hater
