Doing a 5sp conversion and was wondering if the half, intermediate, mid shaft from a 94-97 accord is the same as the 90-93 version. Also would it bolt up to an H22A tranny correctly? (M2A4) Looking at the conversion parts list, it says use the shaft from the same year accord. I've had no luck with finding one from a CB7 at the local junkyards.
CD5 Half Shaft Compatible?
The best way to see if the parts are the same is to get ahold of the OEM part numbers; for example, use Majestic Honda's exploded diagrams.
94 Accord half Shaft #14
90 Accord half shaft #18
You're in luck, the part numbers are the same, 44500-SM4-020. If they were different, the part numbers would be different.
So next time if you need to compare something, do it this way so you don't have to wait all day for someone to reply back. I mean you're probably eager to get the conversion started at least.Last edited by Leung; 10-10-2012, 10:07 PM.
Originally posted by Leung View PostThe best way to see if the parts are the same is to get ahold of the OEM part numbers; for example, use Majestic Honda's exploded diagrams.
Use rockauto.com and click the blue part number and it will show all the vehicles it goes to or crosses to.
