I was planning on getting a magnaflow cat back with a Catalytic converter but my car is already not street legal and will be too much to get it legal in California. Now I'm debating on keeping it straight piped with the magnaflow but am wondering if even having the magnaflow cat back but no cat will still be very rattle canny, or if the diffusers in the muffler will get plugged up or damages the muffler quicker. I want it loud but not rattle can, and for the muffler to live long what should I do
Magnaflow muffler without catalytic concerter
Get a cat, even if its not California legal. I believe you can get a 48 state universal Magnaflow for under $100. Definitely worth running it. Will help the exhaust sound nice, and the car won't stink like crazy and be a gross polluter. Something is better than nothing. I had a Magnaflow catback, and even with a stock cat it was PLENTY loud.
As everyone else said get a catalytic converter, preferably a high flow variety. They do wonders for getting rid of that tinny sound as you describe it and if you get your car inspected it's one less thing you'll need to fix. You also aren't losing any power worth mention if you have a good high flow cat.
I'm curious, why your car is already not street legal?
Since your car is not street legal, is it a track-only car? Or do you just drive illegally?
As said, get a cat. Catalytic converters exist for more reasons than simply complying with the law. It's very true that you don't lose much power as a result of using one, and your car will sound better, smell better, and emit fewer environment-killing toxins. Not to mention the fact that the laws can always get stricter... so the more you break, the more reason you give lawgivers to crack down even harder on us. Living in California, you certainly know how difficult the law makes it to pursue our passion for modifying cars. Don't give anyone any more reason to make it harder!
Running without a cat only makes sense on a heavily modified track-only vehicle that must extract every last horsepower from the engine. However, the kind of build that would bring about such a situation would be worth more than half a dozen absolutely pristine CB7s.
The exhaust on my CB recently came apart at the flex pipe so a buddy and I welded on a new flex and ran it straight back with a down turn dumping right before the rear tire. Stock resonator is still in place.
There's an awesome loud raspy tone from 2500-3000 and if it shifts in that range it makes a funny sound, barks like a diesel truck. Open it up a bit and close the throttle fully and every now and then she'll give you a nice backfire, wonder if she spits flames? Its really tame in the city if you granny it but on the highway its quite droning cause you're right above that raspy rpm range. Real neat sounding at idle too.
I have a thrush muffler I want to fab up in there but the car has other more important needs to address.
Originally posted by JTL_91CB7 View PostI installed the new cat back, and it's sounds aweseome, not as deep as I thought nor loud which is good. Sounds like a true 4 banger. Not tiny, not raspy, nice deep hum, I recommend it
