Go Back   CB7Tuner Forums > Parts & Performance > Appearance > Lighting
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 07-01-2008, 05:38 PM   #21
MikeW
Master Of Posting Nothing
MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock! MikeW has a HUGE cock!
Send a message via Yahoo to MikeW
Ed Zachary!
Which is why that argument is void. But while arguing that point, there was talk and questions about LEDs in general.
Originally Posted by Jarrett View Post
MikeW is offline   Reply With Quote
Old 07-02-2008, 10:39 AM   #22
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
the problem with LEDs is that while they produce a comparable amount of light to an incandescent, its focused forward, and doesnt project as far. so as long as you have LED "bulbs" that have multiple LEDs facing every which way, youll be fine with them for brake lights and blinkers, because all they have to do is light up the lense/housing. but for reverse lights, you want light projected as far out behind the car as possible. normal LEDs wouldnt even be hardly visible, so the only option would be some very high intensity LEDs that actually produce a ton of heat, and would require at the very least passive heatsinks, and could easily get way too hot contained in the tiny reverse light spot, and burn itself out.
for the reverse lights, regular bulbs are still the best option.
Old 07-02-2008, 10:55 AM   #23
bagoon316
bagoon316 is cool... so far.
Send a message via AIM to bagoon316
so for the rears with the 1157 bulbs, meaning the lights/brake lights bulbs, do you need equalizers? or is it just for teh bigger bulbs that blink equalizers are needed?
Originally Posted by d112crzy View Post
So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
bagoon316 is offline   Reply With Quote
Old 07-02-2008, 11:00 AM   #24
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
the load equalizers are only needed for blinkers, because the flasher relay times itself based on how much current the blinkers draw - and with an LED in place of a regular bulb, its such a low current draw that it trips the relay to blink fast.
the only issue youd have with the brake lights is the "tail lamp" failure indicator in the gauge cluster - which the first post explains how to bypass.
Old 07-02-2008, 11:03 AM   #25
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
as for the front bumper lights being blinkers/always on, that is not functionality that can be gained by installing LEDs, since LEDs act as just a straight replacement for the original bulbs.
some wiring changes would need to be made for this, and there are other threads explaining how to do this. you can do it with a relay setup, or get a new socket that accepts a 1157 dual-filament bulb instead of a 1156 single-filament bulb. but this is a little beyond the scope of this thread, if you need help see if you can find the other threads (theres a number of them)
Old 07-02-2008, 07:32 PM   #26
MikeW
Sweet. Answered those questions, lol. Thanks Mike.
Old 07-02-2008, 07:59 PM   #27
Losiracer2
Originally Posted by greencb7inkc View Post
I ultimately plan on making every light LED. cp[mike] style!
I think my next ones will be the bumper lights and license plate bulbs.
haha, even headlights? or are you gonna do a TSX retro like I did?
member's ride thread
99' Lexus LS400 155k VVTi V8 gets up & goes...new DD
91 Accord SE 176k
97' Honda Odyssey 196k miles...$485 spare van for my parents
Old 07-02-2008, 08:05 PM   #28
C91BLX7
C91BLX7 is very helpful C91BLX7 is very helpful C91BLX7 is very helpful
I don't know why this is happening but sometimes, most of the time actually, the brake lamp light still comes on... I can get it to shut off buy turning the car off on off on really quick. Then it stays off till the next time
I have my high mount bulbless if that matters?
wat?
C91BLX7 is offline   Reply With Quote
Old 07-02-2008, 08:58 PM   #29
GameChewer
GameChewer is cool... so far.
Send a message via Yahoo to GameChewer
Bulbs replaced:
-All 4 rear tail/brake light bulbs - RED 4 1157 LED BULBS
-Both rear turn signal bulbs - AMBER 2 1156 LED BULBS
-All 4 front corner bulbs - AMBER
-Both rear license plate bulbs - WHITE
-Both front bumper signal bulbs - AMBER / WHITE
Im Confused about the others
GameChewer is offline   Reply With Quote
Old 07-02-2008, 08:58 PM   #30
MikeW
Drew, try putting the highmount bulb back in. If it goes away, then there's your answer. If it doesnt, then sounds like you got some rewiring to do son!
Kai, they actually make LED headlights, believe it or not, lol. They didnt look like something id use on the street, or at night, but definitely cool nonetheless.
I just find it hard to believe that an LED could put out the light needed to drive down the road...
Old 07-02-2008, 08:59 PM   #31
C91BLX7
I tried with the high mount in, still does it
wat?
Old 07-02-2008, 09:07 PM   #32
GameChewer
this is what my shopping cart looks like at superbrightleds.com
4 1156-x19 LED bulb $ 6.99 $ 0.00 Wide
Amber 1156-A19
$ 27.96
2 1157-x19 LED bulb $ 6.99 $ 0.00 Wide
Red 1157-R19
$ 13.98
4 WLED-x6 LED bulb $ 2.79 $ 0.00 Amber WLED-A6
$ 11.16
is that right?
Old 07-02-2008, 09:08 PM   #33
C91BLX7
Looks correct, now you just need to order 4 load equalizers or run down to autozone and pick two pairs up.
EDIT, you need 4 RED 1157's looks like you just have 2 there.
wat?
Old 07-02-2008, 09:09 PM   #34
MikeW
Originally Posted by GameChewer View Post
Bulbs replaced:
What are you confused about?
The front corner bulbs and license plate bulbs are all 194. The front bumper lights, i forget, but they can be replaced with 1156.
Old 07-02-2008, 09:12 PM   #35
MikeW
No.
All together you need:
1157 x 4 --- (brake/tail)
194 x 6 --- (corners and license)
1156 x 4 --- (rear signals and front bumper signals)
Old 07-02-2008, 09:13 PM   #36
GameChewer
http://www.superbrightleds.com/cgi-b...e/commerce.cgi
Ok. but on here i can not find 194s.
Old 07-02-2008, 09:15 PM   #37
MikeW
Gimme a sec, but you can find 194s on Ebay or at AutoZone.
Not sure about Advanced Auto or O'Reilly's.
If not superbright, i know a site.....
Old 07-02-2008, 09:15 PM   #38
C91BLX7
194/168 wedge are all the same
http://www.superbrightleds.com/mini-wedge.html
wat?
Old 07-02-2008, 09:17 PM   #39
MikeW
http://superbrightleds.com/mini-wedge.html
Right therrrre.
The first few bulbs they list replace 194s.
Btw, theyre based in STL. 2 hours from me. Yay, me.
Old 07-02-2008, 09:18 PM   #40
MikeW
at double linkage.
bulb , conversion , led , light , tail
