Helmholtz resonance eh? I've had an idea about using a linear actuator to actively adjust runner (itb's actually) length. I think Ferrari does this now. I have no clue how to calculate the resonant frequency and how it relates to gas flow for the engine.
jdm92_accorn : 1992 Accord LX
That's the throttle body I'm running. I have double stacked IAB's and the IAB is functional on the top plate.
I guess you are running them with no IAB's, but are you gutting them (cutting out all the individual ports in the plates)?Bought from: Night Wolf, bassrock234, sonikaccord, 904drACCORDMANG
92 Accord, F23a franken-engine, N/A forever.
Originally posted by jdm92_accorn View Post
For the notch, How did you make the "mark" to line up on the flywheel? Is it another piece that you swap over from the f22? (I only have the f23 out, the f22 is still in the car). I can see it through your notch in the picture but I can't picture it on my block.
Also, do you keep your balance shafts active? belt off? or shafts removed and blocked?
Thanks!Bought from: Night Wolf, bassrock234, sonikaccord, 904drACCORDMANG
Originally posted by dwhacks View PostThat's the throttle body I'm running. I have double stacked IAB's and the IAB is functional on the top plate.
Originally posted by Rilas View PostHas the new throttle body helped with the Helmholtz tuning method?
any flywheel for the f22 will have the timing mark. if you use the f23 lower timing cover and crank pulley it has the timing marks on it aswell. i did it the other way due to running the f22a cover.
What I meant was the mark through the hole in the block. Did you cut that little "v" to line up with the mark on the flywheel?
Also, I guess one can remove the sensors that are on the crank pulley side under the timing cover and crank pulleys? I don't recall though being on the f22a.Bought from: Night Wolf, bassrock234, sonikaccord, 904drACCORDMANG
You'll love freeway driving with the Accord 5th in an H tranny, but I'm sure you already knew you would .*** Think of others before thinking of yourself. ***
MRT
Selling on Ebay!
15.10 @ 90.42mph
Current fastest Laguna Seca Lap: 1:52.889
