domesticated : 1993 Accord SE
    Originally posted by domesticated View Post
    Uh... yea lol. Car is literally going to be a shell with powertrain, brakes, suspension, and lights.
    Nice! Say good bye fogs if you go the turbo route
      Haha. Maybe...
      '93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
        I actually may use an Arduino to control it I've had one laying around and I wanted to use the Arduino to monitor wheel speed and maybe some other things too so maybe that'll work out.
        I was saying the ECU sends out a 'signal' to the vreg in the alt. The ELD just tells the ECU how much and when, hence the reason it's wired there first.
        Arduino sounds fun, and you'll have more control over when the alt loads your engine. If that's the case, you should pick up a smaller or more efficient alt while your in there. Less load= more available power.
        YouTube Clicky!!
          That's a possibility down the road, but I'm just trying to get it running right now lol.
            So much interesting stuff going on in here.
            And i see some goodies for me in those pics...
              I've ordered an Odyssey 680MJ-T, Innovate Motor sports MTX-D water/volt, oil temp/pressure, an MTX-L wideband, Innovative 95 duro mount kit, a slew of o-rings and gaskets for the engine, and new FUCAs through Majestic. I'm just going to build me own relay board.
                Is that last sentence to be read in a pirate's voice?
                  Lmao. I didn't get it at first. And then I luld...
                    Brakes are bled and holding! Adjustable brakes FTW.
                      I bought the same gauges for water/volt , oil temp/pressure. Only difference is I also got the innovative scg-1 gauge. Innovative makes great products, you will be happy.
                        Uh, if anything would ever get here. Got the battery, the mounts just shipped yesterday, but that's it! Today I got the PS lines cleaned and reinstalled. As I did that I realized the M2Y4 was in a car that must have not had PS. So I swapped the VSS from the H2U5 to it. The teeth and pitch are the same, but non PS VSS gear was twice wide. I don't think it will be a problem. Also got the Hondata gasket and lower mani torqued down and removed the plates from the spacer. I don't think she's gonna make Gridlife. Also brakes don't look to be leaking so that's awesome. And I can't find my clutch tool. That fricken sucks. No one has one on the shelf.
                          So what track(s) are you planing on running your car? Are you going to be running for fun or in competition? By clutch tool do you mine the alignment tool the centers it? When do you need it by?
                          CB7TUNER.com
                            Gingerman, Waterford, Mid Ohio, just a few. I don't pLan on competing any time soon. And yea, the alignment tool. I need it by right now haha.
                              Cool, Since its the home track Mid Ohio is the first one I want to take the wagon around a few laps. I have no competition plans i just want to do a few HPDE.
                              Sorry i'm not close enough to give you the clutch tool right now.
                              CB7TUNER.com
                                Just ordered S300 V3. I can just throw away my instrument cluster now because of the android app!
