Go Back   CB7Tuner Forums > Parts & Performance > Swaps
Old 04-11-2009, 01:03 AM   #1
Loafer987
CB7tuner Member
Loafer987 is cool... so far.
H23A vtec lack of torque.
I am having issues with getting good bottom end out power of my H23A vtec swap. The engine has a fat fat fat top end. As soon as i hit vtec it pulls harder than my old H22A civic that had a lot less weight but below vtec it doesnt even pull as hard as my F22A6.
So far I am running:
P13 ECU
M2B4 Transmission
Act 12 lb Flywheel
Exedy Stage 1 Clutch
timing 15* BTDC. ( My ditributor is all the was toward the rad side of the engine in order to set it there. and yes i used the jumper wire to set it)
my fuel rail is running 45 PSI without vaccum. approx 41 at idle with vaccum.
I just got my injectors cleaned and flow matched and this is when the top end really started to pull insanely hard.
Running 91 to 94 octane. (pulls WAY harder when running ethanol blended fuel. but my F22 did the same.)
I am still working on getting a chipped ecu and dyno time to play with this thing more.
__________________
^Click Me!^
Loafer987 is offline   Reply With Quote
Old 04-11-2009, 12:38 PM   #2
bruno8747
Contributing Member
bruno8747 is cool... so far.
Send a message via AIM to bruno8747
If you have to clock the distrubitor that far off just to get factory ignition timing, then the timing is off mechanically. Meaning that the timing belt is off one tooth or so.
__________________
bruno8747 is offline   Reply With Quote
Old 04-11-2009, 04:46 PM   #3
Loafer987
CB7tuner Member
That makes sense but wouldnt that cause the car to do other weird things? what about that fuel pressure? Does anyone know the stock fuel pressure for an H22A without vaccum? i have an adjustable regulator and i am curious if that could cause it?
The distributor is an H23A housing with all the F22A internals. I just assumed this was the problem with the distributor. The H23A non vtec and H22A vtec distributors have more adjustability so i may try that if i can get my hands on one.
I will check the timing possibly tonight. Any other ideas are appreciated as well.
__________________
^Click Me!^
Old 04-11-2009, 04:58 PM   #4
d112crzy
CB7tuner Member
d112crzy seems to have made some friends!
It's definiltely either the cam timing or lack of tuning. P13 won't run that motor the way i needs to be.
__________________
d112crzy is offline   Reply With Quote
Old 04-11-2009, 05:26 PM   #5
customchord
Contributing Member
customchord is cool... so far.
Quote:
Get a socketed P28 and find a tuner.
__________________
-1991 Honda Accord LX H22a-
customchord is offline   Reply With Quote
Old 04-12-2009, 06:03 PM   #6
Loafer987
CB7tuner Member
So nobody has a good idea of what the fuel pressure should be? Please someone let me know. I have searched all over and I cant find it here.
__________________
^Click Me!^
Old 04-13-2009, 02:07 PM   #7
Cmqqn85
CB7tuner Member
Cmqqn85 is cool... so far.
fuel pressure should be between 33-40 psi w/o vacuum. Thats straight out of the OE honda prelude manual for a 1993 H22a1
__________________
90 Accord DX H22/LSD Swap DD
01 S2000 Silverstone
90 Civic DX K24/K20 ~ Track Whore To Be!
~TeamDOHC.org Join Today~
http://teamdohc.org/forums/index.php
Cmqqn85 is offline   Reply With Quote
