I just put a p12 ecu in my lx coupe 5speed with an f22a1. Would an a6 cam give me more horse? Its seems there aRe so many combinations, wondering if this would be a good idea?
A6 cam with P12 ECU
A6 cam with P12 ECU
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<SoldTags: None
I'm assuming the intake mani would be easier to swap out also? And does the P12 work good with A6 components?
The P12 is meant for an F22A1, it does not support IAB's, so even if you swapped over an a6 or h23 intake manifold, the ecu would not know how to control the butterfly's, which would leave you connecting them to vacuum, which isn't always condusive to making the best power or drivability.
If you want to run the A6 cam, or the intake manifold from an a6 or h23, its better to stick with the PT6 that can control the butterfly's in the intake manifold.
Otherwise look into investing in a p06, getting it chipped, adding iab support, and a good dyno tune if you want to achieve maximum performance from all your engine modifications.
Here are the general parts to do a TRUE a1 to a6 conversion.
A6 Camshaft
A6 Intake Manifold w/IAB black box
A6 Exhaust Manifold & Downpipe
A6 ECU (PT6)
A6 Oil Cooler
A6 Windage Tray
Oh and the a6 uses different valve springs, although a1's valve springs will work without issues for the a6 cam.
To activate the buttefly's you just need to add one wire to the stock ecu connector for use with the PT6, or any chipped ecu.Last edited by cloudasc; 10-12-2011, 11:30 PM.
OK, thats what I'm talkin bout. Thanks guys. Not sure which route to take, I might just go with an H22. K24 sounds to expensive, but a6 conversion sounds doable.
Originally posted by deevergote View PostThe P12 is tuned for a BONE STOCK F22A1. That is all.
The A6 cam and intake manifold would most likely do best with the PT6 ECU.
People talk about the P12 like it's some performance upgrade... and it is, but only for a bone stock F22A1.
