i been doin some work on my suspension and i cant get the radius rod bolts to align in the holes i cant get one but the other one wont align in any help would be greatky appreciated thanks
Cant Align 2 radius rods bolts? Help
Originally posted by YK86 View PostTry loosening the front bolt by the crossmember. It's extremely hard to get the holes to line up unless you loosen the front bolt as well. I just did mine a couple months ago so I know how hard it is if you don't loosen it.
no dont do that. loosen the crossmember bolts. their 17mm and right next to eachother. their like 8" long lol. Then put the radius bolts on. those two bolts and a pain i know how you feel. but loosen the other 2 to get to those 2.miss my turbo cb7
moved onto volvos. dont know how that happened, just did
Originally posted by quickangel93 View Postno dont do that. loosen the crossmember bolts. their 17mm and right next to eachother. their like 8" long lol. Then put the radius bolts on. those two bolts and a pain i know how you feel. but loosen the other 2 to get to those 2.
I loosen the nut because it give me more slack to line up the holes on the arm side than moving the crossmember around. Also, when you tighten the nut back up to specs, I find the caster remains the same.
Originally posted by '93CB7Ex View Postid loosen the radius rod as said before. or just pull the control arm in a little but.
The crossmember holes are actually a bit bigger than the bolts. If you don't put it back exactly where it was before, there is also a chance the caster (hence part of the alignment) will be thrown off.
With the radius rod nut, there is a metal sleeve inside the bushings which will not allow it to compress after a certain point. As long as the nut is tightend back down to specs, the caster will be exactly where it was before you loosened it.
