Old 04-20-2020, 10:01 PM   #61
fleetw00d
Contributing Member
Valve cover looks good. That front cross member is relatively easy to remove. I repainted and replaced the one on my wife's 93 LX a few years ago after she hit a tree with the right front and ruptured the battery.
Old 05-06-2020, 02:15 PM   #62
wtfisafleek
CB7tuner Member
So I've gotten my calipers back from the powdercoaters and I think the finish came out really well.
In the interim since my last update, I also got my exhaust shield mounted back up, and the driveshafts installed. It really is starting to look like it's coming together.
Bolts were installed right after this.
I've also got most of my parts together to refurbish the AC, but I need to rent one of those flush guns and get some solvent, rent a vacuum tank and find a good set of manifold guages to use.
I do need one part if anyone has a compressor they don't need. I stupidly threw out my old compressor before I snatched off the top plate with the pipe fittings. I had no idea the new one would be shipped with a blank friggin plate on top. Ugh.
__________________
My '91 LX build. Bought September 2017. http://www.cb7tuner.com/vbb/showthre...r /> t=209871
Old 05-06-2020, 09:37 PM   #63
dreamability
CB7tuner Member
dreamability is cool... so far.
Damn Brother, looking so good. I really like how the calipers turned out!
Auto-zone loan a tool has the vacuum pump, flush tank and a good manifold gauge set.
They require about $400 down for all of them but you get it back when you return them.
I currently have all them here at the house to put a new system in a work truck this weekend.
They also sell the flush for $20.
Good luck with the AC, hit me up if you need anything.
dreamability is offline   Reply With Quote
Old 05-07-2020, 07:43 AM   #64
SSMAccord
CB7tuner Member
SSMAccord seems to have made some friends! SSMAccord seems to have made some friends!
Send a message via Yahoo to SSMAccord
Nice color choice on the calipers.
SSMAccord is offline   Reply With Quote
Old 05-18-2020, 10:01 PM   #65
wtfisafleek
CB7tuner Member
I've gotten a lot of work done in the past couple days:
Tranny fluid and oil have been topped up. Tie rods installed (anyone notice they were upside down?); radiator, p.s. pump, alternator, spark plugs/wires, and distributor all installed.
Speaking of the alternator - my God, who was the sadist that designed the tensioner for that? Maybe I just haven't figured out the trick to installing it, but I've done it three or four times now and it seems you have to do it just so. It just seems so unnecessary. I guess it wouldn't be so bad if they'd positioned that one A/C line a little differently. BUT NOOOOOOOOOOO....lol.
What's left? I still need to insulate and install the last of the two A/C lines on the trans side of the motor, put in the A/C's fan, fit the radiator hoses and fill it with coolant.
Then I'll bleed the brakes and clutch. After that the battery tray and the battery, then it's time to start her up!
I plan on getting this done by Wednesday hopefully, that way I'm ready to pull a vacuum on the system Thursday in prep to charge it up Friday.
__________________
Old 05-21-2020, 11:16 PM   #66
wtfisafleek
CB7tuner Member
Well I got the engine started today with minimal problems! I'm soooo happy that the idle's not bouncing like my '91's was/is. Upon my first attempt, I wasn't having any luck, but I noticed I wasn't hearing the hum from the fuel pump. Considering some wonky starting/dying behavior when I first got the car, I'm not surprised. Again, I'm very lucky I got it home back in November.
I think I need to bleed a bit more air out of the power steering, but other than that, she idles really nice. I made sure to warm it up, bleed the coolant, and make sure the fan came on ok. No problems there. Here's a link to the video on instagram. Sorry, I should've recorded it and uploaded to youtube or something.
https://www.instagram.com/p/CAeP4tiA..._web_copy_link
I still need to clean the upholstery, bleed the brakes, and mount the wheels. Oh and charge the A/C system. That's it! Wait who am I kidding? There will always be more.
__________________
Old 05-22-2020, 06:33 AM   #67
fleetw00d
Contributing Member
You set all the valve clearances? It just seems like more valve clatter than I remember in most of mine; does it quiet down when warmed up?
Keep the old main relay; remove the cover and resolder any cracked solder joints, then keep it as a spare.
To bleed the power steering, simply turn the wheel from lock to lock a few times, the system should purge itself. Make sure to check and top off the reservoir after doing this.
__________________
90 LX 4dr 5 spd 385,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 191,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
07 Element EX AWD AT (2) 87,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
LOTS of CB7 parts - ENTIRE COLLECTION - FREE
Come and get it.
http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 05-22-2020, 06:51 AM   #68
wtfisafleek
CB7tuner Member
Yes sir, I set all the valve clearances. It's just the video, making it seem more clattery than it really is. I thought I had gotten rid of the air with some spins of the wheel, but I guess not! I will be doing more wheel-turning today, that's for sure.
__________________
Old 06-01-2020, 05:41 PM   #69
wtfisafleek
CB7tuner Member
Just a little update. I've roughed in the toe where it needs to be, but I still haven't torqued down my ball joints because I've got a change of suspenders in the works.
I picked up a set of shocks and springs from u/dreamability. Dreamability has decided to leave us plebian Accords in the dust on the autox course once his Koni Yellows are mounted, so these needed a new home.
They're Koni Reds and like my car, they are old but in much better shape. I gather they were sold new to him in '18 and weren't on the car very long. They came paired with some Vokland (sp) springs and should give a tidy drop, judging by his car's stance before he took them off.
I picked up a spring compressor today, so I'll be working on getting them installed soon. I would've already started on them, but on a 3rd warmup my j'92 decided to start spewing coolant out of one of the few hoses I didn't change - a heater hose. So I had to derail, order one hose, buy the other at Autozone. A pain to get to for sure, but I got them off the firewall from up top, surprisingly.
* BE CAREFUL NOT TO SQUEEZE TOO TIGHT ON THE HEATER CORE'S FIREWALL FITTINGS!* I managed to squeeze mine a bit too tight and make it a little oval, or maybe it was already like that, I dunno. I reshaped it a little bit, hoping it holds. The new hose I got from Autozone is already on, now I'm just waiting on the hose I ordered to get here.
__________________
Old 06-01-2020, 11:00 PM   #70
dreamability
CB7tuner Member
Did you get the purchase receipt I emailed?
New for sure, while sitting on a warehouse shelf in New York for around 10 years before I bought em, lol.
Even now they only have about 2-3000 miles on em.
Definitely a great set up for an OEM upgrade and modest drop.
I think you'll be happiest setting them at 1/4 turn towards stiff or full soft.
Also dont forget to put the rear shocks cir-clip back up to the top setting and leave the front on the lowest.
Glad they found a good home.
I'm looking forward to getting to take the cars out together this summer; you, me and Allen.
Now I wont be the only CB at the meets!!! lol
Yeah I made that mistake with the heater core connections on my 92 back in 2012. Just really soft copper.
They held good after reshaping them and connecting the hoses so you should be good.
