up grading my brake/suspension
    i was goin to start my suspension work this next week i have the xxr 16x8 and the lowering springs and the camber kit i was wondering about if i could use bigger brakes then the stock.. i found a thread
    http://www.cb7tuner.com/vbb/showthre...ighlight=swaps
    it was helpful bt will the bolt pattern change cuz i already have my wheels and i think the bolt pattern off the cb7 stock is 4 over 114.3 however my wheels fit 4 over 100 and 4 over 114.3 they have bolth patterns
    so i was thinking i could use SI civic hubs or something
    PLZ help and give me some threads or point me in the right direction thanks much appreciated..
    You dont need anything Civic for hubs. If the wheels are both patterns, then you can use the wheels without modifying anything since 4th gen Accords stock lug pattern is 4x114.3.
    Now of your looking to upgrade your brakes, try going with the ROH conversion. Prelude Vtec Calipers, Prelude Vtec Rotors, Acura CL hubs, and Accord Wheel Bearings.
    '09 Mini Cooper S (R56)
      thanks
      ROH? im not sure wat u mean about that and as long as my wheels will fit on my car? and i am doin an H22a jdm swap in it in a few months i dident want to run into problems with the axels to fit my hubs and the h tranny?
        You newbies need to use the search option more often. Here it is:
        http://www.cb7tuner.com/vbb/showthre...roh+conversion
        And an example of whos done it properly:
        http://www.cb7tuner.com/vbb/showthread.php?t=68153
        OR
          good threads
          thanks bro good lookin out ya im jus gettin in this shi i had an eg6 and i new pretty much every thing about those but i jus got my cb7 a couple months ago bt thanks again
            for th ROH conversion do you have to get the baring pressed in the cl hub? and how hard is it taking the old hub and Bering out is it just a bolt off?
              theres a race in the bearing that either needs to be cut out or chiseled out. a press would be easiest but not everyone has that luxury.
                that race is pretty hard to take out. you cant reuse a wheel bearing if thats what you are trying to do.
                I <3 G60.
                  http://www.tasauto.com/Product/Browse.aspx?d=1606&p=1
                  ^ tas has "bolt on" conversions for our cars, they arent to too expensive, but it's all brand new parts and doesnt require rigging of hubs they sell them for the conversion. also look at some of the "big brake" kits they have for front and rear they sell a complete front and rear ROH conversion, and if you have rear drums they have that kit also.
                  I recommend this as the other way requires much more work.( but hella cheaper lol) Good luck
                  _____________________________
                  91 Accord F22B
