Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 06-07-2013, 11:46 PM   #1
jdm92_accorn
CB7tuner Member
jdm92_accorn is very helpful jdm92_accorn is very helpful
Send a message via Yahoo to jdm92_accorn
1991 nissan sentra SE+R (B13) Projectsunydaze
so i've mentioned here and there about my brother's SR powered sentra. i just figured i'd finally shed some more spot light on it.
[/url]
[/url]
year:
1991
make:
nissan
model:
sentra SE
engine:
SR20VE(neo VVL, its a variable valve lift and timing version of a regular sr20)
86mm bore x 86mm stroke
10.3:1 compression(stock)
1998cc
oem cam specs
Intake cam
Low lobe: 8.4mm lift @ 220 duration
Low lobe center angle: 110deg
High lobe:10.7mm lift @ 264 duration
High lobe center angle: 104deg
Exhaust cam
Low lobe: 6.6 mm lift @ 244 duration
Low lobe center angle: 122deg
High lobe:10.34 mm lift @ 268 duration
High lobe center angle: 114 deg
mods:
custom 3" SRI
BPi velocity stack
megan racing 4-2-1 header (absolute junk on these. it only has a 48mm collector)
exhaust shop special crush bend 2.5" exhaust (crap)
nismotronics with base tune for VE
trans:
stock b13 SR20DE trans
old setup:
SR20DE
different Intake same Header/Exhaust with JWT S3 cams
out with the old
altering an obd2 b14 ser wiring harness for use on the sr20ve
engine goes in from the bottom. its actually less than a 1.5hr swap once the harness was on the engine.
in with the new
dyno results
after this session we found out that the base timing was off by about 7 degrees. just for reference on the SR20DE 5 degrees timing advance is about 6-8whp. but for now future plans are for SR16VE N1 cams, intake manifold with the oem 70mm TB and one of these headers
with a 3" mandrel bent exhaust and a real tune. it should be a solid 230-240whp. oh did i mention this thing is 2400lbs with full interior+driver and fuel. needless to say if it ever hooks up, it'll be a monster. all it does now is spins 1st-3rd, lol.
jdm92_accorn is offline   Reply With Quote
Old 06-08-2013, 09:03 AM   #2
Clean_4th gen
CB7tuner Member
Clean_4th gen is cool... so far.
Very nice. I have 2 friends with 200sx. Those SRs are badass.
Clean_4th gen is offline   Reply With Quote
Old 06-08-2013, 09:38 AM   #3
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
That's my favorite Sentra of all time. I love those cars!
__________________
deevergote is offline   Reply With Quote
Old 06-08-2013, 03:21 PM   #4
jdm92_accorn
CB7tuner Member
funny story it actually used to be mine. i gave it to my mom and she sold it to my brother. since helping him put his together i've thought about building one my self. the sr20ve has quite a bit of potential for a 2 liter. the main down fall is the oem camshafts. but with the better cams from a pulsar vzr n1 and better intake the difference is huge, almost 30whp.
Old 06-08-2013, 06:03 PM   #5
Macaqueistrong
Boats 'N Hoes
Macaqueistrong is cool... so far.
My cousin has a B13 with the VE swap as well. 2 months ago we installed the SR16VE transmission and he has a set of N1 cams that we will be installing this coming week. He has a airiad 3" intake and an asp header with full 3" exhaust. It is a legitimately fast car. He ran a 14.1 with the VE, stock tranny, and JWT intake.
__________________
Macaqueistrong is offline   Reply With Quote
Old 06-08-2013, 09:19 PM   #6
jdm92_accorn
CB7tuner Member
My brother would be very jealous of that car, lol.
Old 06-09-2013, 09:59 AM   #7
laz93se
ContributingMember
laz93se is cool... so far.
I have always loved b13's. Nice work.
__________________
MRThttp://www.cb7tuner.com/vbb/showthread.php?t=84102 93se h22/t2t4
laz93se is offline   Reply With Quote
Old 06-21-2013, 03:08 PM   #8
Daheavyking
Contributing Member
Daheavyking is cool... so far.
Send a message via AIM to Daheavyking
I love B13s. For the longest Ive looked for a stick shift sedan.
__________________
I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Quote:
Originally Posted by Racer_XXX View Post
Excuse me miss, YOUR FUPA IS IN THE WAY!!!
Daheavyking is offline   Reply With Quote
Old 07-16-2013, 07:32 PM   #9
jdm92_accorn
CB7tuner Member
a little fuel + heat + high rpm back off =
