Go Back   CB7Tuner Forums > 4th Gen-eral > Regional > Pacific > So. Cal
Old 07-07-2010, 10:21 PM   #101
my 9t9d
CB7tuner Member
my 9t9d is cool... so far.
Quote:
Originally Posted by blvs125 View Post
good Luck Mr.adovada King...lol...
i Passed!!!!!!!!!!!!!!!! finally I Efen Passed All I Had To Do Is Get The Correct 02 Sensor And Passed Fast.,... Well Now Im Back On The Road....
__________________
from this
my 9t9d is offline   Reply With Quote
Old 07-07-2010, 11:18 PM   #102
benjerman112
Contributing Member
benjerman112 is cool... so far.
Quote:
Congrats What 02 sensor did you have?
That was smog correct? Not the Bar test?
__________________
Freedom Is Not Free
U.S Army 02/08 Medically Discharged
benjerman112 is offline   Reply With Quote
Old 07-08-2010, 08:10 PM   #103
my 9t9d
CB7tuner Member
i did one that was direct connect and yes bro it was the bar im glad im done with that ish now i can go to the meet on sat.!!!!
__________________
from this
Old 07-13-2010, 11:40 AM   #104
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
congrats man! you know our cars are old when we celebrate by just passing a smog test LOL!
__________________
1cor10:31
- 92 LX coupe
- 96 EX wagon (sold)
timmy0tool is offline   Reply With Quote
Old 07-14-2010, 01:11 PM   #105
bmxicansd
CB7tuner Member
bmxicansd is cool... so far.
Quote:
Originally Posted by timmy0tool View Post
thanks man! i went to chaffey college this past weekend and got it done. thank GOD she passed!
went there with 87 in the tank (accidentally put it in) then added 3gals of 100 octane and drove 40mins to the ref. they basically just did a smog check as they normally do at other test only centers, EVAP test and all. she passed the sniffer and the ref just gave me the sticker! she barely passed (116 was max i got 116, and 91 max i got 91) prolly due to 87/100 octane hybrid gas but she passed!
i thought he forgot i was there to have my swap legalized since he didn't check the vac lines, ecu, nothing! all he checked was the timing and VIN numbers. he said the car was the cleanest honda he's had so maybe that contributed to him not checking the rest. also i was the last car before he was closing for the long weekend and maybe he wanted me out haha. the guy was cool and he knows what he was looking at.
overall i'm happy, finally it's done!
congrats timmy... I agree with the ref your coupe is clean
__________________
Header Whorage and Official Part out sale.
Official Garage Sale Thread
http://jdmconcepts.com/ Head porting specialist..
bmxicansd is offline   Reply With Quote
Old 07-22-2010, 04:14 PM   #106
timmy0tool
thanks craig, i finally don't have to sweat driving around in the coupe. also since it has a/c as well LOL!
__________________
1cor10:31
- 92 LX coupe
Old 04-22-2013, 10:55 AM   #107
Bad_dude
CB7tuner Member
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Question
Any one went to smog their CB with the new STAR station require? What are the newer max values for our cars?
Thanks.
Bad_dude is offline   Reply With Quote
Old 06-07-2018, 03:53 PM   #108
timmy0tool
Quote:
Thanks.
i just did the smog check. see my next post for the latest numbers!
__________________
1cor10:31
- 92 LX coupe
Old 06-07-2018, 06:12 PM   #109
timmy0tool
I'm very glad I had this thread to reference as I just went through this again (as we all do every 2 years). here is my experience for posterity!
things have changed for me since my BAR 8 years ago. I spun a bearing on the H22A so I installed an H23A VTEC blue top and only used the long block, meaning I reused the H22A intake manifold. I also installed a greddy header that I found brand new in box which has a CARB number. everything else on my setup stayed the same. after the swap I was not able to do a proper timing adjustment so I guessed to a setting and hoped for the best. I did do a valve adjustment and used OE Honda coolant in the system. as stated in this thread the car must be in proper operating temperatures before a smog check.
with the given setup above I went to my local STAR smog station and received the following:
meas = amount measured
ave = average for passing cars
max = maximum allowable
15mph test:
1803 RPM
%CO2 meas 16.3
%O2 meas 0.1
HC (PPM) max:81 ave:34 meas:85
CO(%) max:0.74 ave:0.14 meas:0.13
NO(PPM) max:554 ave:269 meas:589
25mph test:
3002 RPM
%CO2 meas 16.3
%O2 meas 0.0
HC (PPM) max:63 ave:26 meas:33
CO(%) max:0.62 ave:0.10 meas:0.03
NO(PPM) max:511 ave:206 meas:127
results:
FAIL HC (PPM) and NO(PPM) tests
the smog tech told me that CA is getting stricter (compare the numbers from my original post, they changed) plus they want to see every CARB number for every aftermarket part I had. the header was cleared since it is marked clearly, however he could not find a CARB number on my cat which is a magnaflow. I told him I passed the BAR with this cat and though he believed me, he said it's the new rule! I also failed the fuel cap test.
defeated, I went home to try and remedy this. upon my research my cat was not a CA-legal cat after all though it passed the sniffer and BAR in years past, so it naturally lacked a CARB number. thus I purchased a newer magnaflow CA-legal cat, which had a bigger element in comparison. it also has the CARB number engraved on the side.
in addition to swapping out the cat, I cleaned up the EGR passage like before as dictated in this thread, changed the spark plugs (NGK ZFR6F-11), did an oil change and actually checked the timing which was off. I did retard it a little, same as before. if -> is normal, I did _> on the timing. I bought a new gas cap and back to the smog station I went!
the techs were able to confirm I had the correct cat and proceeded with the test. he kept the car idling which kept the cat warm while performing the inspection. even while prepping for the rollers he kept the car running. afterwards everything passed, however the tech came to me and said that my header CARB number does not match my BAR sticker which states I have a 1994 motor. in reality the motor is a 1995-up since they never made a prelude VTEC motor in 1994. the header was identified for only a 1996 motor. the BAR sticker was inaccurate and the their CARB number reference was incomplete thus the inconsistency. regardless, the tech easily waved this minor issue and gave me my numbers.
(in parenthesis) = previous test numbers from above
15mph test:
1806 (1803) RPM
%CO2 meas 16.6 (16.3)
%O2 meas 0.0 (0.1)
HC (PPM) max:81 ave:34 meas:42 (85)
CO(%) max:0.74 ave:0.14 meas:0.02 (0.13)
NO(PPM) max:554 ave:269 meas:73 (589)
25mph test:
2916 (3002) RPM
%CO2 meas 15.3 (15.4)
%O2 meas 0.0 (0.0)
HC (PPM) max:63 ave:26 meas:15 (33)
CO(%) max:0.62 ave:0.10 meas:0.01 (0.03)
NO(PPM) max:511 ave:206 meas:0 (127)
results:
PASS test
of course having a new cat does wonders plus I am sure that cleaning the EGR system, changing the plugs, and adjusting the timing helped as well. the numbers dropped dramatically though I was not far off to begin with. remember this is an H23A VTEC blue top but is still running the jdm p13 ECU all OBDI. it's essentially a stroked H22A from the factory anyway minus the oil squirters hence the lower redline.
cheers to another 2 years of driving !
__________________
1cor10:31
- 92 LX coupe
Old 06-08-2018, 05:46 PM   #110
ikayto
CB7tuner Member
ikayto seems to have made some friends!
Send a message via AIM to ikayto
good job tim!
__________________
ikayto is offline   Reply With Quote
Old 11-17-2018, 05:44 PM   #111
4CYLPOWER92
Contributing Member
4CYLPOWER92 is cool... so far.
Nice. Smog techs say the same about my greddy header. They overlook it as well. Funny though, originally when I bar'd mine the header # was not just for '96 and up, it was fine for all obd1 H22's. Something changed in the system.
4CYLPOWER92 is offline   Reply With Quote
Old 12-06-2018, 01:39 AM   #112
f20aaccordturbo
CB7tuner Member
f20aaccordturbo is cool... so far.
Dope
__________________
contact info
(562) 324-3639 chan mao
f20aaccordturbo is offline   Reply With Quote
Old 12-19-2018, 10:06 AM   #113
BreckAConner
CB7tuner Member
BreckAConner is cool... so far.
California sounds like a pain in the ass to pass emissions.
BreckAConner is offline   Reply With Quote
