I always preferred the rare trim or top end lines. So I went & got me the 2nd of 2 SiR's in north America.
>>>MOTOR & GEARBOX<<<
CF2 Body w/ 111k-Miles (Originally 72k-Miles)
JDM H22A Engine
BB6 5 Speed Manual Transmission
DIY PCV Oil Catch Can
Custom Clutch Line
Wrinkle Red Valve Cover
11lbs Light Weight Flywheel
ESP AT To MT Right Transmission Mount
Polyurethane Filled Front OEM Mount
Polyurethane Filled Rear OEM Mount
JDM Under Hood Shield
>>>EXTERIOR<<<
Sherwood Green Pearl Paint (Painted in 2012)
JDM Roof Rack
JDM Front Turn Signals
JDM Power Folding Mirrors
JDM Eagles
JDM "US Wagon" Badges
JDM Bronze Glass
JDM SiR Fogs
JDM SiR Black Housed Headlights w/Corner Lamps
JDM Side Markers
OEM Mud Guards
94/97 Front Lip
Original JDM License Plates
Window Visors (Recleared)
Draw Tie Trailer Hitch
Wiper Blade Stands
JDM BB6 Bumper Pole & Switch
>>>INTERIOR<<<
SiR Black/Grey Interior
JDM Floor Mats All Around
JDM Digital Climate Control
JDM Road Flare & Holder
JDM Half Mast Switch & Wiring
OEM Security Switch Plug
OEM Rear 6th Gen Accord Trunk Rubber Mat
Honda Access Rear Cargo Net
1st Gen Legend 5spd Shift Knob
Wooden Center Console Bezel
Prelude Shifter
Optional Security Switch LED Display
>>>SUSPENSION/WHEELS/STEERING/BRAKES<<<
Eibach Wagon Lowering Springs 1.4"F 1.5"R
Brembo Wagon Rear Rotors
Brembo Prelude VTEC Front Rotors
NEW Duralast Ceramic Brake Pads All Around
Acura 2.3 Front Hubs (ROH Conversion)
225/50ZR-16 BFGoodrich g-Force Sport COMP-2 Tires
JDM LorBor Rims
Rear Upper Control Arm Spacers
KYB AGX Adjustable Struts All Around
Front Polyurethane Strut Mounts
SPC Front Upper Camber Ball Joint
>>>AUDIO/ELECTRONICS<<<
USDM Honda Radio
Honda Optional Equalizer
OEM Inferred Keyless Entry
DOT MPH Gauge Conversion
HIDs w/Micro Ballasts
Valentine Radar Hard Wired
>>>STUFF IT ONCE HAD BUT NOW REMOVED<<<
Original SiR Gunmetal 15" Rims
Original Springs
JDM Cassette Radio
JDM Yokohama Ecos 205/50/R15 Tires
JDM H22A Auto Transmission
OLD Lowering Springs
ESP Left Engine Mount
>>>NEAR FUTURE PLANS<<<
5spd Swap<<<DONE
Trailer Hitch<<<DONE
Timing Belt Job<<<DONE
SPC Adjustable Upper Ball Joints<<<DONE
New Brake Pads
New Brake Rotors
Euro-R Intake Manifold
Clutch Reservoir Bracket
Clutch Line
Replace Power Steering inner Boots
>>>FAR FUTURE PLANS<<<
VIP Dish Rims
Tint Front Windows
Subwoofer
Double Din Radio
Replace Antenna Mast
Install Bumper Pole<<<DONE
Install Cornering Lamps
LED Headlight Bulb Kit
Replace Front Window Regulators
Black Polyurethane Suspension Kit
Replace Hatch Struts
Hasport Mounts
Long Rear Upper Control Arms
Replace Hatch Seal
Replace Rear Main Seal
Replace Oil Pan gasket
Add Back OEM Flywheel
Install Flywheel Cover
Replace Shifter Cables
Dash LED Mod
Add Cruise Control
SiR Lip Kit
Add USB Outlets
>>>MAINTENANCE WORK DONE<<<
NEW OEM Valve Cover Gasket
NEW OEM Balance Shaft Belt
NEW OEM Air Filter
NEW OEM Door Side Protector Moldings
NEW OEM RHD 5spd Brake Pedal
NEW OEM Roof Rack Rubber Pads
NEW OEM Roof Rack End Caps
NEW OEM Clutch (EXEDY)
NEW OEM Pressure Plate (EXEDY)
NEW OEM Battery
NEW OEM Battery Heat Shield
NEW OEM Rear Main Seal
NEW OEM Timing Belt
NEW OEM Oil Cooler Seal
NEW OEM Camshaft Seals
NEW OEM Crank Seal
NEW OEM Rear DOHC Seal
NEW OEM VTEC Solenoid Gaskets
NEW OEM Transmission Axle Seals
NEW OEM Header Gaskets
NEW OEM Power Steering Fluid Tank
NEW OEM Power Steering Hoses
NEW OEM Inner/Outer tie Rods
NEW OEM Radiator Cap
NEW OEM Front Window Regulators
NEW OEM Wiper Cowl
NEW OEM Side Door Openings Long Trims
NEW OEM Fender Rubber Trims
NEW OEM Front Upper Control Arms
NEW OEM Front Lower Control Arms
NEW OEM Intake Manifold Gaskets
NEW OEM Front Lower Ball Joints
NEW OEM Front Wheel Bearings (Replaced Twice)
NEW OEM Cruise Control Cable
NEW OEM PCV
NEW OEM Front Balance Shaft Seal
NEW OEM Rear Balance Shaft Seal
NEW OEM Clutch Master Cylinder
NEW OEM Clutch Slave Cylinder
NEW OEM Fuel Filter
NEW OEM Door Window Moldings
NEW OEM Window Trims
NEW OEM Windshield Trim
NEW OEM Windshield Washer Nozzles
NEW OEM Door Seals
NEW OEM Window Seals
NEW OEM Hood Seals
NEW OEM Water Pump
NEW OEM Exhaust Manifold Gaskets
NEW Electrical Load Detector For Fuse Box
NEW Disturbitor w/Rotor & Cap
NEW Iridium Spark Plugs
NEW NGK Spark Plug Wires
NEW Power Steering Belt
NEW Alternator Belt
NEW AC Compressor Belt
NEW Ignition Coil
NEW Throw Out Bearing (KOYO)
NEW Alternator
NEW Passenger Axle
NEW Drivers Axle
NEW Radiator
NEW Strut Bump Stops All Around
NEW Fenders
NEW Hood
NEW Power Steering Rack
NEW Brake Master Cylinder
NEW Brake Booster
NEW Brembo 4th Gen Prelude Front Rotors
New Brembo Rear Integra Type-R Rotors
Brake Proportioning Valve
Replaced Rear Hatch
Replaced Fender Liners
Replaced Front Bumper Liner
Rebuilt Alternator
Valve Adjustment
